Question about HP DeskJet 1280 InkJet Printer
Help- HP 1280 not printing on thick photo paper
Help- my HP 1280 will not printing on thick (~250g/m2) photo paper (glossy), even type HP. With other papers works good.
The printer refused evermore the APLI Photo bright Paper (240g/m2, glossy) and rather the HP Advanced Photo Paper (250g/m2, glossy), both with instant drying quality.
Thanks, Sandor from Romania
5 Suggested Answers
getbharti
  • 33 Answers
SOURCE: Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Posted on Nov 28, 2008
  • 199 Answers
SOURCE: HP PSC wont feed through glossy photo paper. Paper
hp printer support low gsm photo glossy like 130-170, or only hp photo glossy they have rough back side to run paper properly
Posted on Feb 27, 2009
  • 3 Answers
SOURCE: I'm using HP Advanced Photo Paper, Glossy to print
try fanning the paper and flicking through it before loading, it may just be sticky.
Posted on Nov 26, 2009
esound
  • 425 Answers
SOURCE: I am trying to print some 'buisines cards off my
Hi,try placing a sheet of fine sandpaper in the paper tray. As soon as it
starts to feed grab it so that it polishes the glaze off the rubber
feed rollers. Let us know if this solves the problem.
Thanks for using fixya.......
Posted on Dec 02, 2010
What is the maximum paper weight allowable for the HP LaserJet 2840 printer? I am printing recipe cards but 4x6 or 3x5 cards are too heavy and the printer won't take them.
Handle a variety of business needs. Spend less time loading
paper with an input capacity of up to 375 sheets. A 125-sheet
multipurpose tray and a 250-sheet paper tray offer easy
access to a variety of paper finishes, sizes, and types,
including labels and envelopes, at weights of up to 47 lb
(177 g/m2) and HP laser glossy and photo papers up to 70 lb
(220 g/m2).1
Jun 08, 2010 | HP LaserJet 2840 All-In-One Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
I am unable to print photos usingthe HP Photo Papers
Does it print on normal paper ?
If it does is then you need to look at the material you are trying to feed, there a limit on what thickness of material your printer will happily accept
Media comes in all different thicknesses and forms (We make the stuff) and some printers will struggle to feed 200gsm photo glossy etc
You could try cleaning the infeed rollers with an alcohol based cleaner to improve their grip.
Even Gin or Vodka will suffice as they both clean and evaporate quickly
Jun 12, 2009 | HP Photosmart D7260 Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
HP 6940 rejects 8.5" X 11" glossy photo paper for printing
Is it a front feed and then the output is also goes out to the front? Coz if your glossy paper is to tough that it will not bend easily, this is what you get. Why not try to use a thin and more flexing photo paper if the outcome will be the same.
Usually when using thick paper the most desirable printer should be a top feed-front output with almost less than 90 degree bend.
Apr 24, 2009 | HP Deskjet 6940 InkJet Printer
Photo paper jams.
please check the thickness of the paper maybe its too thick to print try a 180 gsm it will help.
yours
alecz
Mar 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP DeskJet 1280 InkJet Printer Logo
193 people viewed this question
Seeker5211
Seeker5211
