Question about Timex Expedition 40141 Wristwatch
Timex Expedition Adventure tech altimeter Watch: Screen is blank except for the sun symbol and two dashes below that; there is no response to any of the buttons. Is the battery dead or do I need to send it in? I love the watch, by the way, esp. the alti and baro modes and use in my outdoor mycological activities. (The light does not work either).
What is chrono in timex adventure tech?
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
http://assets.timex.com/user_guides/W215_M179/W215_M179_NA_EN.pdf ??
Feb 07, 2011 | Timex Expedition Adventure Tech Compass...
The stop /reset button has dropped out of my Timex Expedition T41501 Altimeter Watch. Where can I get a spare and is it easy to fit? John Polak United Kingdom
Thank you for contacting FixYa.<br /> Im sorry, but you will have to send into Timex to get this repair. This is not a repair that a novice can do,<br /> I did find you a link to a repair site in UK. Best regards. Jewel<br /> <a href="http://www.timex.co.uk/contact_us.aspx">http://www.timex.co.uk/contact_us.aspx</a>
Aug 26, 2010 | Timex Adventure Tech Altimeter 41501 Wrist...
Replacement band
mcdevito75 here, Look for a small watch repair shop in your area, to save on costs, new band and labor.
Jun 25, 2010 | Timex Expedition Adventure Tech Compass...
Hello, I don't understand how to calibrate the altimeter
May I get the make and model # of the watch to help you more
Jan 22, 2010 | Timex Adventure Tech Altimeter Barometer...
I have a Timex e-tide with compass, temp and tide functions. The compass no longer points north and will randomly point in any direct when activated, is there a way to re-calibrate the compass?
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 13, 2010 | Timex Expedition Adventure Tech Compass...
How does the altimeter function work? we can't find it on the enclosed instructions
Altimeters on watches are usually based on barometric pressure, since the pressure changes all the time you generally need to adjust the altimeter to a known altitude. You can look on USGS website to find the altitude of your area, or simply type in "altitude of city, state" in a search engine.
I hope I understood your question; if not, please reply.
Oct 17, 2009 | Timex Adventure Tech Altimeter 41501 Wrist...
I recently had my battery changed on a timex expedition adventure tech altimeter watch, now the chime doesn't work and the alarm doesn't beep. Please help. Thank you.
You can attempt to have the circuit board reset if it has an "AC". This may or may not fix the problem. Usually when a sound board goes out you have to replace the whole circuit board or movement.
Sep 14, 2009 | Timex Expedition Adventure Tech Altimeter...
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Expedition Adventure Tech Compass...
I'm looking for a watch strap for a ladie's Timex expedition Adventure Tech watch. Where do I find one??
Timex stores are the only place I have been able to find their straps consistently. If you have a standard lug set up you might be able to get a similar after market strap at your local repair shop.
For Timex locations visit their web site...
Timex.Com
Sep 12, 2009 | Timex Expedition Adventure Tech Compass...
ADVENTURE TECH WATCHBAND.
call 1-800-448-4639, give them the watch model number. Band will cost about $10.00
Oct 08, 2008 | Timex Expedition 84601 Wristwatch
Timex Expedition 40141 Wristwatch Logo
290 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
