Question about Whirlpool Duet GHW9150P Front Load Washer
Wash cycle not starting.
When I start a load of wash it is not beginning the cycle it blinks "sud" on the time screen. what does that mean?
  • Michael Masters
    Michael Masters May 11, 2010
    are you using the correct HE detergent?
  • 51 Answers
THAT NEANS YOUR USING TO MUCH SOAP, ONLY USE HE DETERGENT AN A TEASPOON FULL. THE PUMP IS DETECTING THE SUD AS WATER. RUN UNIT WITH "HOT" WATER A COUPLE OF TIMES . THEN IT SHOULD BE GOOD
Posted on May 16, 2009
I have an lg tromm front load washer. I am getting the IE fault. I have cleaned the inlet screens and drain filter. It gets stuck at the 13 min mark, seems like it just won't go to spin cycle.
LE code mean suds have built up. Using non he (High Efficiency) detergent or too much detergent will cause this error most front loaders use he detergent only there is a he swirl on the container
Let your washer sit idle or 45 minutes.Unplg washer as well
Plug in and turn on as left spin speed select no spin press Start/pause to start a drain only cycle. When cycle is complete remove load. Start a rinse•spin cycle to clean out residue.
If the sud were too much you may have to repeat
Jul 25, 2015 | LG Washing Machines
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
What does LE mean?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 28, 2010 | LG WM-2277HW Front Load Washer
The words Sud comes up in the rinse cycle. What does this mean?
You are putting too much soap before you begin the wash cycle...... When the word SUDS is displayed then on the rinse cycle there is too much soap and the suds are still on the clothes. Try cutting back on the soap, maybe cut back almost 1/2.
Jul 12, 2010 | Kenmore HE2 Plus Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Le error what does it mean?
Initially unplug the washing machine.
While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
If you still face problem then follow the procedure :
Hope this helps .
Apr 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine keeps shutting off and has the letters LE in the display. What's going on?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
It could also mean the hall sensor is defective and will need to be replaced.
Feb 12, 2010 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
