Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
Water is not comig out!
This the 3rd Machine we've bought (two times D90, and third time a C100), but the problem is nothing is working! We fill the container with cold water, switch on, wait until the blinking stops, then press the "cup" button: nothing comes out but a little whining noise! We also follow the "troubleshooting" steps, but it doesn't help! Are we doing something wrong here?
  • heo35 Dec 22, 2007
    Did you ever figure this out? I just got the D100 which I think is pretty similar. I did the troubleshooting and haven't come up with anything!
  • Anonymous Jul 25, 2008
    Not perforating the foil end of the capsule
You might be inadvertently skipping the following step: after filling the container and switching on, after the blinking stops I believe you are supposed to lift the top lever and ... before putting in the coffee, press the "cup" button for about 5 seconds so that water is primed to come out. You do this every time you turn the machine on, NOT every time you make an espresso. I had the same problem as you did and then looked carefully at pictoral instructions and realized I was skipping this crucial step!
Posted on Jan 13, 2008
I found that the valve on the bottom of the water tank (held in place with a spring) was not aligned correctly - i was able to rotate it slightly using a toothpick then followed the priming instructions and my machine resumed working correctly.
Posted on May 24, 2009
Occasionally, the Nespresso will not puncture both sides of the capsule. When that happens, the machine makes a whirring noise but water does not come out.
Posted on Apr 01, 2008
Where to buy replacement water tank for Nespresso Essenza C100
I need to find a replacement water tank for my nespresso essenza C100 coffee machine. Mine broke, any ideas where I might be able to find one?
Jan 12, 2013 | Nespresso Essenza C100 Espresso...
Why does my bleach dispenser cup fill up with water every time I do a load of laundry?
I agree with grady709 about the plugged inlet lines, I had water left in my Samsung front load all the time and made sure the machine level and nothing wrong with venturi. I suddenly had water leaking from somewhere instead and when I took the top off I could feel the line swell up and leak at the fitting. Hose still leaked after replacing. Put a drill bit by hand down the nozzle where the hose clamps on and it was plugged up and also the bleach line was plugged up, also inside where the tray goes there is small holes in the top where the water sprays out can be plugged. Worked for me. Live where the water is hard.
Nov 24, 2012 | Samsung Washing Machines
Every time I use my New Hoover steam vac it leaks all the time I've tried every thing, I even bought a new tank same problem, I'm not taking it to be repaired its the 3rd one thats done it an
After the second time I would have asked for a refund. Maybe you need to do some diagnostic work.
1. Does it leak while sitting unplugged?
2. Does it leak while plugged in but not being operated?
3 Does it leak when the solution is above or below a certain level.
4. Are you over filling it?
5. Does it leak only when you pull the trigger? (valve problem)
Keep asking yourself questions to discover where and why it's leaking.
Good luck.
Nov 13, 2012 | Hoover Max Extract Steam Cleaner
Hotpoint H2O error
Please check on the water flow to the drum, if the flow is low or if the inlet is choked the water flow in the set time limit can be low and so could trip.
secondly it can be due to problems in the level sensor, try and see if the pressure switch works outside.
Finally check on the program controller unit once again to see the triping. check the door switch for loose connection.
check this link for tips:Washing machine
Jun 25, 2012 | Hotpoint Washing Machines
I just bought my machine and I've been using it for one week. Today, I filled the water tank for the 3rd time maybe and I put it back, but the light for "empty tank" stays on and the machine does...
Try removing the water tank and verify that there is nothing clogging or blocking the valve that allows the water to flow from the tank to the machine.
Once you have verified that the valve is clean and undamaged, try putting the tank back in to the machine again. If there was nothing blocking the valve, then the issue may have been that the tank was not completely seated within the coffee maker.
Dec 30, 2010 | Nuova Simonelli Oscar Coffee Maker,...
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
Water does not come out ...is there a fix
mcdevito75 here, Make sure everything is set to make coffee, New or clean filter, filter basket set in machine. Your coffee maker might need cleaning also.------------ Fill resovoir with white vinegar, let it run thru the machine 3 times, half way thru ther 3rd time stop machine and let stand for 30 minutes. resume brewing, then fill resovoir with water and let run thru machine 2--3 times to get rid of vinegar. If this don"t help you may need new coffee maker.
Jul 09, 2010 | Mr. Coffee TFTX85 Coffee Maker
Indesit IDL40, 2nd & 3rd light flashing
It can also be that the pressure is too week. If you look a tthe manual it mentions this exact symptom. I know because i ve a similar issue. cheers
Dec 13, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
3,764 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
