Question about LaCie SAFE MOBILE HD-W/ ENCRYPT 160GB 160 GB USB 2.0 Hard Drive
Lacie Safe Mobile Factory Reset
How can i reset to Factoy Default my Lacie Safe Mobile Drive? The protection in ON now, but the finger is not mine. I think if i can reset it, the protection wil be lost. No problem for data on the disk, i don't need them.
  • 171 Answers
SOURCE: lacie big disk 2.0 usb
Format the drive with NTFS.
Posted on Jan 26, 2008
  • 287 Answers
SOURCE: LaCie Hard Drive, FA Porsche model
If the disk is FULL then you have used all the space, this is not uaually a fault but you may need to look at the data on there and delete any old stuff you dont need. IF you need it all then you should buy a larger capacity drive.
use "my computer" to see the drives connected to your PC. The lacie should be easily identified by it's name. Double click on the drive and you can explore the files/folders.
HIH
Posted on Jul 16, 2008
zzptichka
  • 95 Answers
SOURCE: recover data from a non responsive LaCie F.A. Porsche Hard Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads and it's not something you can fix by yourself.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Posted on Nov 11, 2008
  • 537 Answers
SOURCE: lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Posted on Feb 07, 2009
  • 78 Answers
SOURCE: LaCie external hard drive data lost
Try PandoraRecovery. Free.
www.pandorarecovery.com
Posted on Jun 30, 2009
I want to restore the factory default settings of my nokia 2630 but when putting the default code "1235 " getting code error. As far as I remember I have never changed that. I have even tried ...
Factory settings This is possible to reset your Nokia to factory settings (Note that you will lose all your data). For this look in the manual of your phone. Soft Reset Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380# This function apparently works on almost all nokia mobile phones. Hard Reset It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset Enter the code: *#7370# and press Yes to confirm initialization. Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc) To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons: on/off + * + 3 Before making a Hard reset better backup all your important information: contacts , memo...etc
Mar 10, 2011 | Nokia 2630 Cellular Phone
My lacie hdd 500GB, i forgot the password to get into the online interface someone please tell me what the defult might be and if there is a way to reset the password if it is not the defult without...
-Turn the drive off
-When pushing the power button to switch the drive ON, keep holding the power button until the blue LED of the power button starts to flicker and then release the button.
-Then, after 1 or 2 seconds the button's LED should flicker with another rhythm.
-Push the button again. After a few seconds, the LED will flicker again but with a third different rhythm. Release the button. -If the drive turns off then the power button was held in two long during the last step, please try again if the drive powers off.
The product should now be reset to its factory default settings.
In the logon window that opens, type:
    User Name: admin
    Password: admin
(This user name and password is the factory default; if you have already created a user, input your user name and password. This is the administration logon and you can change it for more security if you choose.) The NAS Administration page will open in your default browser.
Dec 09, 2010 | LaCie Big Disk External USB 2.0 1TB Hard...
No message but showing phone memory full and not able to send or receive msg
I think you have to do a factoy reset
Before doing this you should know the lock code.
The above mention key sequence is a normal reset.
Press *#7780# Restore factory settings.
Hope it helps.
If the issue persists use this.
Deep Reset (*#7370#) : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten(contacts & messages- all phone memory will be gone).
Take a back up if you want something.
Good Luck.
Jun 05, 2010 | Motorola Mobility MOTOROKR EM30 Cell Phone
I cant see my external lacie hard drive on my mac. Was part of an ethernet network and able to use ok by 2 imacs and p. All of a sudden not visible anymore.
Just contact www.lacie.com great support. their answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Feb 04, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My lacie hard disk 1tb all of a sudden isnt
Just contact www.lacie.com great support. their answer for my drive was to reboot the drive. For me it worked.
Jan 27, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have external hard lacie it work normal before two day but now it cannot detect
Dec 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
I forget my security privacy lock password for message of samsung SGH- Z240 mobile phone. What is the default password or lock code to access in security privacy lock of message?
Hello s_a_rocky,
Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings.
Thank you for using FixYa.
Jan 15, 2009 | Samsung SGH-e315
Memory Full for Nokia N70
I think you have to do a factoy reset then.
Hope it helps.
Good Luck.
Live, Love, Laugh.
May 13, 2008 | Cell Phones
Mobile reaparing
Hope it helps.
If you want to know how to format, ask me.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Nokia 6300 Cellular Phone
LaCie SAFE MOBILE HD-W/ ENCRYPT 160GB 160 GB USB 2.0 Hard Drive Logo
912 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
