Question about GE Spacemaker JVM1640SJ Microwave Oven
Whenever I open the door on my GE Spacemaker XL mircowave the internal fan goes on. This is the fan that goes on when the unit is cooking and not the exhaust fan. It goes off as soon as the door is closed and then goes back on when I start the unit to warm up food. Thanks for the help.
  • 150 Answers
That is normal for it to spin for about a second or so becuase of switch changeover but should not remain on constantly when door is open. Have it checked up if it does not happen like the way I described it.
Posted on May 13, 2009
GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Over range microwave model JVM1443LK01 This started a couple days ago. After removeing something from the microwave and we shut the door, the fan started up. The fan will run as long as the door is...
I would check the door switches for a faulty switch. If it were condensation on the control panel. I would think it would have dried out by now unless it has damaged the control board.
Mar 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL from 1998. It was working fine yesterday but today the display window shows all asterisks. I have unplugged it for several minutes in an effort to reboot it. It asks for a...
Wow! sounds really weird. Possibly Microprocessor on Main Timer board. No way to really diagnose other than substituting or replacing the main board. Unfortunately a bit pricey. Nothing else i can think of that would actually cause asterisks in the display. I really do not like to refer them, but may need to call GE since it is one of their units. Maybe they could give you some guidance. Mostly, over the phone, they just insist on sending someone out. So they can bill you more.
Aug 23, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1440wh04 GE Spacemaker. no microwave cooking
Could be an open internal fuse or magnetron failure
Mar 07, 2018 | GE JVM1440 Microwave Oven
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven JVM1440 Two weeks ago after I press 6-express cook stopped and all the lights and clock went blank. In a 10-15 minutes it came back on and the clock would have to be...
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker 2.0 Microwave
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | GE Profile Spacemaker Over-the-Range...
GE XL 1400 Spacemaker Microwave
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
In many brands, there is also a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
217 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
