Hi-I keep getting a flashing ''battery low'' light come on that is annoying-when its plugged in! I never use just battery only; I always use it plugged in. Whats up?DRC6327A RCA DVD player
    President:
  • 814 Answers
You may have ruined your battery by not using it. These are memory batteries and need to be used just like the one on laptop computers. you should try totally discharging it and then try recharging it to see it is working properly. If not you will have to purchase a new one to get rid of you problem.Hope this helps you with your problem.
Posted on May 16, 2009
The connection light keeps flashing red on the mouse. It works fine but the light keeps flashing and is very annoying. I have changed the batteries and it continues to flash.
so it works but is flashing red i suggest you try this unplug it for a few hours and then plug it back in if that does not work then your mouse is getting ready to die so go out and by a new one
Mar 23, 2011 | Computers & Internet
Is the lightening bolt supposed to flash orange? The battery will not keep a charge at all, so I have to keep it plugged in all the time. Does the orange flash mean I may be in danger of losing files, etc....
The orange flashing lightening bolt is confirmation the battery does not charge. It is not an indicator of any other hardware failure.
You can remove the battery if you find the flash annoying. The laptop will be lighter without the battery too!
Sep 21, 2009 | Dell Inspiron E1705 Notebook
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Red Battery light flashes when computer is turned off
The reason the battery indicator would flash is because its reaching the end of its useable life. Meaning that it will become harder for the battery to keeps its charge until it finally doesn't keep a charge at all. best thing to do is when your not using your laptop unhook the charger to it so its not always charging the battery.
To fix the problem though you'll have to get another battery unfortunately.
Jun 02, 2009 | Dell Inspiron B130 Notebook
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
May 20, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
The Charger light flashes orange 3x and green once but it wont charge
Your battery has died, of a fail safe has kicked in. The orange light indicates that the battery isn't charging properly, and needs replaced. Replace the battery and it will be fine. Keep in mind that batteries are just batteries, they eventually wear out, and some faster than others. Also, the more you use the battery, the faster it will wear out, so I always recommend keeping the machine plugged in when possible.
Aug 25, 2008 | Dell Inspiron 8000 Notebook
Af and flash button flash continuously when camera switched on
How old is the camera? Take a new approach to Nikon. But costs are about right- it is no joke.
Aug 10, 2007 | Nikon Coolpix 5600 Digital Camera
My TV won't turn on. The Green light just keeps on flashing
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Jan 30, 2007 | Mitsubishi WS-73713 73" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
