Question about Brother IntelliFax-2820 Laser Fax
The brother fax 2820 keeps signaling to me to close the back cover no covers are open
  • Brother Expert
  • 159 Answers
Open that back cover, and you'll see another, black plastic plate that also can be pulled to swing down. Running across that plate is a skinny black rod. At the right-hand end (when you're peering in the back of the machine) it has a couple of right-angle bends, ending in a vane that should swing through a curved slot in the side wall inside the machine. That vane interrupts a sensor to tell the machine that the door is open or that paper is jammed in the back. Sometimes it gets bent with the vane outside the curved slot. Gently bend it enough to drop it into the slot, close everything up, and try it out.
Posted on Aug 05, 2009
What we can do for brother fax-2820 " DRUM ERROR"
open front cover with the machine on and press the options key.message will appear replace drum unit then select 1 for new.close cover
Oct 25, 2012 | Brother IntelliFax-2820 Laser Fax
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
Back Cover Open Close The Back Cover Is Message I'm getting. What is the Problem?
Open the front cover and remove the drum and toner(cartridge).
There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
May 31, 2010 | Brother IntelliFax-2820 Laser Fax
Fax display says, close back cover even with back cover closed.
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Jammed paper
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Apr 06, 2010 | Brother IntelliFax-2820 Laser Fax
HOW DO YOU TURN OFF DRUM LIGHT ON BROTHER 2820
Open front cover....press 'options', and select 'new drum'
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC-7220 says close back cover but it's already closed
May 13, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine broken need to forward to different fax
HELLO! OPEN THE BACK DOOR AND CHECK IF THE SENSOR FELL OUT, IF YES PLEASE SNAP IT BACK IN WITH OUT BREAKING IT
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
273 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
