Question about Mr. Coffee TFTX85 Coffee Maker
Can you take a mr.coffee maker apart to clean it?just the top part?Is it okey that I already cleaned it by putting soapy water in it letting it brew,then putting regular init and letting it brew.
  • 17 Answers
SOURCE: Mr Coffee
If your coffee maker is under a year old, take it to a authorized service center for free repair or replacement.If its over a year then the complete heating element assembly must be replaced.However, this part is only available to authorized service centers and is not sold to consumers.
Posted on Nov 07, 2007
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
buffalonyman
  • 1865 Answers
SOURCE: Mr. Coffee FTX23 quit brewing
The heating element burned out, its a common problem. Mr. Coffee tend to leak, I've had several of them.
Posted on Jun 10, 2009
  • 186 Answers
SOURCE: my mr. coffee coffee pot won't brew. it will make
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
Posted on Nov 05, 2009
SOURCE: Brand new Mr coffee PSTX
If you look where the reservior fits into the base, specifically where the water goes in, there is a rubber seal. It's held in by a circulary plastic piece and 3 screws. I took it apart there to see if something was amiss and decided after looking at it some that they had put the seal in upside down. So I put it back together with the lip of the seal facing up instead of down and I have not had a single drop of water leak from the reservior again. Now if I can get the thermos pot that came with it to stop leaking every time I pour a cup I will be a happy camper.
Posted on Jan 30, 2011
Coffee stopped brewing well, coffee now brews weak. Even with increased coffee grounds. Clean button won't turn off. Even after 2 clean cycles.
Chances are there are built up scales inside the brewer. Are you using regular water? If so, you may have to descale it. Look for a food safe descaling chemical which you may have to flush with clean water in several cycles. Another solution is to take it apart and clean it. Problem is, you have to be skilled to do this.
Jun 19, 2016 | Mr. Coffee BVMC-PSTX91 10 Cup Programmable...
Where is the charcoal filter in a mr. coffee self clean maker
The filter fits on top of the regular coffee filter basket.
I don't use the charcoal filter because the water I use to make coffee is already filter in my Brita pitcher.
Aug 07, 2014 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee tastes funny. does machine need to be cleaned?
Yes, in this type of machine, put a little bit of vinegar and water in top and run a couple times through machine, with of course filter basket on, not with filter or coffee, and brew a couple times. Use 25percent to water ratio, do this twice then do it again, twice with only mineral water. Then make a pot normal, and let me know how coffee taste now. Thanks Mr Bean Man
Jun 09, 2011 | Bunn VPR Coffee Maker
The light is on to clean it and I do not have an owner's manual. Can you please explain? How do I get the light to stop blinking?
Most coffee makers are cleaned by filling the reservoir with undiluted white vinegar (3 cups). (Do not add coffee.) Remove the water filtration disk if you use it before starting. Then start the brew cycle as if making a cup of coffee (including putting a paper filter or the permanent filter in the filter basket and close the lid). Put a decanter on the warming plate. After brewing, turn off the coffee maker and let stand for 30 minutes. Run another cup of vinegar through the coffee maker. Take the decanter filled with vinegar and discard the liquid (pour down the sink drain). Rinse the decanter. Fill the reservoir with clean water and put in a new paper filter (or clean the permanent filter and put it back). Again do not add coffee. Run a brew cycle to rinse the unit. Discard the water that is in the decanter after the brew cycle. Do a second clean water only brew cycle (with new empty paper filter or permanent filter after cleaning again). However, if you notice an odd taste, repeat the rinse cycle.
You can alternatively use the Mr. Coffee Coffee Maker Cleaner (mix as directed on that package). In either case, this removes mineral deposits (calcium from hard water). For soft water, the cleaning should be done every 80 brew cycles. If you have hard water, do this every 40 cycles.
The manual is available from www.mrcoffee.com/Product.aspx?pid=121 , if I have the correct product version. For some reason this site isn't coming up for me today. Check the manual to find out if there is any specific details for cleaning that aren't shared with other Mr. Coffee products.
I hope this helps.
Oct 29, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
How do I take apart, and clean my coffee maker?
The only parts that should be removed to clean are the pot and the basket. The remaining parts you just clean with a cloth and hot soapy water (squeezed out) then you clean the inside with 1 part white vinegar and 1 part water. Run a cycle through the pot then run again with just plain water. This do once every 3-4 mos. depending on how often you use your coffee pot. You can actually put them on the top of a dishwasher rack also. You may risk electrical shock if you take it apart.
Oct 09, 2010 | Mr. Coffee FTX49 12-Cup Coffee Maker
I live in a limestone area and the flow through my Senseo coffee maker is slowly reducing. How should I descale it?
Believe it or not, vinegar is a blessing for cleaning nearly anything out of your coffee maker.
Fill your water reservoir 1/4th full with vinegar, then fill it the rest of the way up with water.
Run the coffee maker, then let it sit for about 10 minutes. Pour the mixture back in to the reservoir and run it again. Let it sit another 10 minutes.
Dump the mixture and use plain water this time. Let it sit for another 10 minutes. Dump the water, then repeat with clean plain water.
Wash the filter basket and pot with hot soapy water. If the vinegar smell is still present, just run it again with plain clean water.
Oct 10, 2009 | Philips Senseo HD-7810 Coffee Maker
Cannot put my coffee maker on delay cause the clean light cmes on,how do I clean cannot find the instructions on it
Had the same problem and had to run white vinager though the system 3 times and it not only cleaned it but I got better tasting coffee. Make sure to run clean water through after the vinager. Hope this helps! armgst
Sep 10, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
My coffee maker works very slowly after about three weeks of use. Specifically, the water does not pass through the filter and into the pot quickly, if at all. Suggestions?
Try cleaning it with white vinegar. Put in one cup with a potful of water, and let it soak. To get more cleaning, pour the water/vinegar through again, hot. Put in a coffee filter to catch/strain the debris, and you will be able to see if it's helping. When you're through cleaning, pass fresh water through the machine by potfuls, until no traces of vinegar can be detected.
Best regards, --W/D--
Aug 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
My coffee maker will not pull water from the resevior?
if you want, you can take it apart and clean the coils, but just buy a mr coffee for 17 bucks at walmart. good coffee taste.
Aug 03, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
Feb 09, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee TFTX85 Coffee Maker Logo
118 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
