Question about Emerson Televison & Video
Emerson EWD2004 vcr eating vcr tapes
When playing or recording, can hear clicks like its setting up but then will spit tape out. eventually, will eat tape.
    President:
  • 2,992 Answers
This is caused by mechanical problems in the VCR. Depending on the age and maker of the VCR, the take-up reel in the cassette is driven by a gear, a belt or a rubber wheel. This isn't happening properly in your VCR, so the tape is piling up inside. Given the low cost of replacement combo players (I don't think you can find just a VCR these days), it's not worth having repaired. You can expect to spend $60 to $100 on a repair for this kind of trouble, assuming there are even shops still willing to take the machine in.
Posted on May 13, 2009
  • 431 Answers
The usual problem with VCR's that eat tape is the rollers and belts that they use , over time they become warn and stretched .
This happens particularly with the pinch wheel that feeds the tape through to the guide rollers that pass the tape around the spinning helical scan head system .. one guide roller folds around mechanically each side of the head and locks into position
the tape runs off the feed roller in the tape cassette on the left of the machine , past the control and sound head also on the right with a roller to effect good contact on to the the head rollers that then pass the tape around the head in a precise track to scan the tape off from there to a tension arm that keeps the tape against the scan head to the pinch roller that pulls the tape through the machine if this wears the tape will rise and fall on the roller shafts causing tape damage .. also after the pinch wheel is the take up spool back in the cassette that should it stop will cause the tape to fold thus causing damage to tape ( there is a sensor on the spools that should tell the machine when they have stopped a magnet attached to the spool base passes a control head at regular intervals confirming to the tape deck mechanism that the tape is moving ) all the movement within the deck is monitored but unfortunately slow to react and by the time they have registered the damage to the tape is usually done . That is why it is so important for pinch rollers and drive belts to be in prime condition and should be replaced on a regular basis . This can be quite a complicated process and requires some dismantling of the machine both mechanical and electrical , it can be accomplished by a dexterous layman but is not advised .
Regards Vortash
It is advised that only qualified engineers should try to repair electronic equipment for obvious safety reasons ..
Cassette tap in my vcr get eating
The unit has a bad transport mechanism--it among other things moves the tape in play etc and when ejected winds the tape back into the cassette.
Could be bad belt/s or a bad idler made of rubber that does this type of function.
If a old unit may be better to replace if you can find one new.
Apr 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
The vcr of my dvd vcr combo is eating tapes and will not play
the vcr needs a re alighnment,(on the tape path)and maybe a idler as well needs to be repaired
Jul 05, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Emerson EWV601 eats TAPES...2 springs on right side when looking at machine. 1 is not attached to anything. Where does it go to pointed up toward wall
The spring probably goes to the pinch roller. Try cleaning the heads and demagnetize the heads. This happened to me with a sony, but it works now. hope this helps, !
May 21, 2010 | Emerson EWV601 S-VHS VCR
It ate the tape. Got the tape out but it wants to
run a wet cleaner tape through, the playing heads and rollers are dirty.
Feb 14, 2010 | Emerson EWV603 VHS VCR
VCR is eating tapes
There are different reasons that a VCR could start eating tapes. It could that it just needs a good cleaning or it could have a mechanical problem you will really need to have it checked out by a service center to determine why. If you have small children I would check it for signs of “peanut butter sandwiches. J
Nov 29, 2009 | Philips Magnavox DVD/VCR Dual Player
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Picture blinking on a Sharp Quos HD TV
A lot of times with recorded tapes, the tape that's inside doesnot work well with vcr s. I have had this problem with old and new vcrs and if you keep trying then the device will eventually eat the tape.....
Apr 10, 2017 | Televison & Video
VCR problem in EWR2OV4
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle. The pincher wheel can become worn and/or dirty from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out than can be wound up. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Televison & Video Logo
308 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
