Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Westinghouse LCM-22W2 has "ghosting"
My monitor was given to me by an employee that is leaving our company.... it is is 6 months old. The color is all perfect. The only problem is a "ghosting" impression to the right of anything on screen - the cursor, words, images, even the left hand edge of the screen! By "ghosting" I mean that there are colorless multiple images of screen items trailing off to the right. The darker color or thicker the item on screen, the "deeper" the ghosting impression appears to be. While it doesn't affect the reading of larger text, it makes smaller, thinner text very "shimmery" and more difficult (though certainly not impossible) to read.
  • Frank Zhang
    Frank Zhang May 11, 2010
    you need check LCD panel vable first, clean and replug that cable, if still "ghosting" feedback me
    Sniper:
  • 51 Answers
Here you can download the user manual of you monitor..
http://www.westinghousedigital.com/manuals.aspx
Posted on Jun 23, 2009
  • 221 Answers
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
Posted on May 13, 2009
Trying to program my Westinghouse LCM-22w2 ComputerMonitor/TV with my AT&T U-Verse Remote Control. What's the code?
There is no tuner in the monitor, it only works as a TV with a tuner added. The remote would work with the tuner, not the monitor !
Dec 11, 2010 | Westinghouse LCM-22w2 Television
Monitor Brightness
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
Feb 02, 2010 | Westinghouse LCM-19v1 Monitor
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
Can't find correct setting for westinghouse lcm22w2 monitor
I don't know if this actually will fix your problem, but all LCM 22w2's are plagued with the 'white screen of death' and eventual power shutoff, including garbage characters and faulty menu, video output, etc. Here's how I fixed it.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supplyboard. This is a common problem plaguing motherboards and LCDflatpanels that use capacitors from Taiwan. If you know how to solder,or know somebody that can, it's actually a pretty easy fix. Take outthe yellow circuit board on the inside, write down the specificationsfor each of the capacitors (the cylindrical things) go to theelectronics supply store and get the replacement capacitors. You can goover the voltage specification (not under), but keep the capacitancevalue matching. Replace one at a time. Go to www.badcaps.net foradvice, tutorials and training on doing this. *You really shouldreplace all the capacitors*, but the very large one next to the powerplug I did leave on the board because I couldn't find a match. To mydelight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
http://www.ctcco.com for professional hosting solutions
Jan 07, 2009 | Westinghouse LCM-22w2 Television
My Westinghouse LCM 22w2 (1 year old) has developed a green line running top to bottom of the screen. I cannot get rid of it. I've tried turning the monitor off, changing inputs, reseting - but it's...
Unfortunately that is a failure in the display electronics and is repairable only by replacing the display panel. I don't know what the warranty period is for this model, but check your purchase date and the warranty information. If the thing is just recently out of warranty maybe the manufacturer will work with you on a solution. Or you can contact them anyway and ask. Sometimes if you complain loud enough it works wonders.
Dec 06, 2008 | Westinghouse LCM-22w2 Television
No image on my Westinghouse LCM-22w2 monitor
I fixed it! It's the power supply board.
Your problem isn't precisely the same one I had, but I have the feeling you're not saying that this was a problem that gradually got worse over time and now it won't power up.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to www.badcaps.net for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the white screen of death went away and it was working as new!
Nov 13, 2008 | Westinghouse LCM-22w2 Television
Monitor shuts off for a few seconds when i play games or watch videos.
I fixed it! It's the power supply board. The bad news is you need to solder.
Dec 16, 2007 | Westinghouse LCM-22w2 Television
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
583 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
