Question about Garden
Mower running rough
I have a briggs and stratton 40 quicksilver 46s on a flymo push mower and it is running fast/slow,also chucking out a bit of smoke,also using alot of petrol,any ideas?ta
  • Samuel Charles Spriggs May 11, 2010
    Have you performed routine maintenance on the engine lately -- like air filter cleaning/replacement?
  • 41 Answers
This engine may need overhauling,You seem to have either bad valves or rings, or both.
Posted on May 13, 2009
Hi,I have a Briggs and Stratton Quicksilver 46SD, runs eratically and smokes
Hi,first take the old gas out of the mower and reflll with new.Restart mower and let run for two to three mins.....If it's still smoking you have bad piston rings.
Mar 05, 2015 | Garden
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
I have a quicksilver 46s petrol need oil in the petrol ???
No it is either a Briggs engine or a Techumseh engine neither of which is a two stroke, so check the oil in the engine and run the machine on un leaded fuel.
Apr 16, 2012 | Garden
My briggs and stratton mower runs rough but when I toggle choke on and off it runs better for awhile
have to use choke means fuel problem. Check your fuel cap vent, fuel filter. Fuel solenoid opening with key turn on. Remove hose from carb.and see fuel runs out.
Mar 10, 2012 | Craftsman Garden
My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
Jun 19, 2010 | Briggs & Stratton Garden
Flymo quicksilver 46s keeps cutting out
make sure button not cracked also fuel filter sits in bottom of tank get you a peice of coat hanger and fish it out just pulls off the end clean it good and also double check your carb sometime you can lose a gasket and it will cause similar issues? let me know if any of this helps ? can also tell you how to adjust high speed side of carb if all else fails?
Aug 29, 2009 | Garden
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
Garden Logo
814 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
