Question about Fisher and Paykel GWL11 Top Load Washer
Washer will not drain
My fisher paykel washer gwl11 will not drain. The pump hums but will not drain.
  • Anonymous May 17, 2009
    How do you check the line?
    Problem Solver:
  • 12 Answers
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
Posted on May 14, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Hi I have a fisher and pykel fresh smart drive 9 and its filled up with water but wont drain,ive tried advancing the cycle but all I get is a humming noise.please help
The humming noise is due to the drain pump being jammed due to clogging of dirt. All you need is to remove the drain pump and do a full clean up. You can also try to tap on the drain pump while it is humming as it will release the dirt and wash off.
Sep 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
Drain pump removal on F&P GWL11
Try to drain all the water out before removing pump.
so motor and other parts don't get wet when you remove pump.
Mar 23, 2013 | Fisher and Paykel GWL11 Top Load Washer
Hello my Fisher Paykel washer will go through the
clean the pump at the bottom of the washer (its the piece with the fan attached); also check the hoses at the pump
Jun 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel washing machine will not spin
Most likely something stuck in the pump, you need to look underneath to get to it, the pump turns anti clockwise to remove it.
Apr 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Jun 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Question
no belts ..direct drive ..lean washer back pump is a twist lock no tools needed hose clamp can be removed with fingersremove pump and ck for lock impeller also ck the diverter valve just behind pump
Jul 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
760 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
