Splendide 2100XC Logo
C
Carl Schroeder Posted on Dec 12, 2013
Random noises randomly the unit will make numerous clicking noises as if its turning on and beginning a cycle or as if it is working within a cycle. Middle of the night, middle of the day, these noises begin and occur for 10 to 15 seconds. Anyone else experience this?
  • Kathy Brandt Jan 03, 2014
    I started having this same problem yesterday. It has happened 3 times. Last time was about 2am. I opened the door and left it open. I closed it after I got up and it has not happeed again. My 2100XC is about 18 months old.
    BTW, this is our first problem, and the door has never been forced.
Fuel pump going out or something else?
There are numerous reasons for a vehicle to stall at random. Is the check engine light on? If so, scanning for codes would be a good place to start. Having a fuel pump pressure test performed will let you know if there is actually a fuel pump/power supply issue causing the stalling
I hear a random clicking sound when im on the phone but the person on the other end doesn't hear it
View topic - Loud clicking noise randomly during phone calls - Ooma
www.ooma.com/forums/viewtopic.php?f=4&t=13207
Jan 19, 2012 - The clicking noise can only be heard by myself ... ... Loud clicking noise randomly during phone calls ... I have not tried calling from a landline.
Weird Popping/Clicking Noise during Call ' MacRumors Forums
forums.macrumors.com > ... > iPhone > iPhone
Jul 4, 2010 - I have experienced the same popping and clicking sounds. .... I want tohear if what your phone is doing to see if mine is the same. share.
How can I tell if my Phone is being tapped? - Nathan M. Smith
https://sites.google.com/a/.../howcanitellifmyphoneisbeingtapped
May 4, 2010 - I have heard clicks while talking to some of my friends across the country ... in use and i hear a crackilng sound.. what is going on... im not a criminal....... Even on my cell phone i will hear unidentified beeping and random dial ...
I keep hearing a clicking sound in the background - Tested
My 2002 chevy malibu's radio seems to be shorting out, the radio will work fine but randomly the sound shuts off the radio still shows the radio station and even says which artist is playing but there...
I'd suggest using the balance and fade controls to cut out each speaker one by one. to possibly determine if you have shorted speaker or speaker wiring. As far as the turn signal clicking noise, the hazard switch is the actual flasher unit for the turn signals, and could be the culprit, but the most likely cause is the turn signal switch itself. It is usually caused by corrosion across the contacts, which can be cleaned out fairly easily, but more typically, the switch is just replaced
Monitor goes white.
if the monitor turn white but the power light is stay on with green, then probably the back light tube was defective, and it will happen randomly in beginning and getting worse after while.
Random clikcking noise from 4-way flasher
most flasher for the blinkers and emergency flashers use the same one it is built into the Eflasher switch. Some of these had recalls take it to dealer and have them look it up
Random play feature
Try going in to your player and creating a playlist.Go into your player through " My computer". When it brings up your main folders, right click on the music folder and click create playlist. All the songs you have will be bunched into one playlist.
Then while your player is paused, hit mode, scroll to the playlist you created and then set it to random play from there. Should work.
Stops working
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
TV Turned off, now there is a clicking noise when plugged in.
had a 51" GE rear projection donated to myself. While off and power button pressed there was a clicking noise from the front of the unit. Rear cover was removed and it could be observed that the hv splitter had a crack in the casing and the power was arcing out of the splitter. I purchased a $72 dollar hv splitter, i read that the $20-$30 dollar one would break within a year, and the unit powered up no problems.
Top Splendide Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ADMIN Andrew
ADMIN Andrew
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
