Question about Symbol MC70
Webexception an error message cannot be displayed because an optional resource assembly containing it cannot be found at System.Net.HttpWebRequest.FinishGetResponse() at...etc, etc, etc. Above are the details of the error (which the error message simpy styates the first 2 lines of this issue) I am having. Basically we use the MC 70 in a distribution environment and we pull orders and count items. The program works until we hit the save or pull button which just tells the program to post data back into SQL Server 2005. We use another porogram to establish and handle the connection called eConnect. I have 3 total MC 70's and 1 of the 3 works. I installed the exact same software on all three and have verified that all the settings match. Thanks for any solution you can provide. P.S. Software is as follows: scanwedge NETCFv2.wm.armv4i sqlce30.wce5.armv4i sql.wce4.armv4 (only because the program will not launch without it being installed...i do not know why that is the case)
  • dustin765 May 14, 2009
    Thank you very much.
    Seeing the error is extremely helpful.
    The error it returned was: Could not establish connection to network.
    So...I went into WIFI under settings>connections> where i modified the adapter.
    Everything works!
  • 12 Answers
Your program that is using the .net compact framework is the one failing (not catching an exception), but because you haven't yet installed the optional resource strings for reporting error messages in .net cf apps (a big mistake by the .net cf team by making that optional), you're not seeing the real error message. You're only seeing the "an optional resource assembly containing it cannot be found". Install System_SR_ENU_wm.cab on the device, then reproduce the error. This time you will see a better error message.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk, push-to-talk over WLAN for warehouse devices - FREE for up to 5 users)
www.radicomm.com
Posted on May 14, 2009
Pro-Plus error Panel 03
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
to external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
Remember PCA, mean Printed circuit assembly with the componentsattached.
God bless you
Jan 14, 2013 | Exercise & Fitness
404 not found
The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server, but the server could not find what was requested.
The web site hosting server will typically generate "404 - Not Found" web page, when users attempts to follow a broken or dead link, hence the 404 error is one of the most recognizable errors users can find on the web.
A 404 error should not be confused with "server not found" or similar errors, in which a connection to the destination server could not be made at all. A 404 error indicates that the requested resource may be available again in the future; however, the fact does not guarantee the same content.
Mar 11, 2012 | YouTube Computers & Internet
The screen says "an error
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
hope this helps
Apr 07, 2011 | Computers & Internet
I keep receiving mail failure error messages form "my mailbox" that I did not send although the address is mine. What is happening and how may I stop this?
Yahoo mail is related to networking telecommunications. First ascertain that the computer network structure is in place. For example, trace dial up telephone line network connections as least allowing media displays. Also recognizable with dial up internet connections is least displays considering the structure from which shared resources are attained. For example, dial up least has enough shared capacity to contain media especially with picture videos least displays also recognizable as error messages on computer. Alternately, computers that are networked with Ethernet as high capacity network structure has an enormous capacity to display media either picture graphic viderograpic or extensively. Wireless networks has an innovated capacities compared to Ethernet cable networks. In situations that computer resources are in place to support media display should least produce malfunctions discussable. First, the resources like with yahoo website experiencing malfunctions from host provider least displays on computer. Refer with the yahoo website experts with issues of malfunctions. Usually whenever, yahoo were experiencing malfunctions would be made available on network site by administrator of resources. Also, encountering conditions as member requires informing the appropriate entities responsible to rectify conditions to make functionality attainable as before. Improtant mail conditions with networked structures include creating spaces within mail boxes to allow resourcefulness. For example, yahoo mail boxes that attain huge volumes of resources least display appropriately either as slowness or malfunction messages requesting defragmentation. Also, in situations that the mail box has materials that are malicious to computer would leas display either that device recognizes malware or has already been infiltrated with virus program. Computers that have antivirus program scanners should be activated to rediscover the yahoo mail experience. Also, ascertain that the computer f feature of protective mechanisms is relaxed to capture resources from an area on the network internet. For example, computers that been set to antivirus protect would hamper the media displays from several location including the internet.
Feb 27, 2011 | Yahoo Mail
Errror 81003005 wont let me sign in to yahoomessneger
ok, in my case i remembered I tried using a proxy on internet explorer and forgot to put it off, so the proxy connection was still on even though the proxy was dead.
It now a proven fact to me that internet explore settings are linked to yahoo mess!
so make sure your internet explorer is working ok without proxy:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
good luck =)
Dec 07, 2008 | Yahoo Messenger
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Error Contacting Update web service
I don't know what program you're using, but usually when you get the message "An error message cannot be displayed because an optional resource assembly containing it cannot be found", it is because the program is using the .net compact framework but the file System_SR_ENU_wm.cab has not bee installed on the device yet. That .cab installs the resource file that is missing. Once it is installed on the device, you'll see a better error message than the one you're seeing now.
Thanks,
Brad Radaker
Radicomm (maker of QuickTalk - push-to-talk for the MC9090)
www.radicomm.com
May 07, 2008 | Zebra Symbol Technologies MC909X-G Series...
Chat session not working
Hi again,
There is no problem with your chat software.All you have to do is just have alot of patience once your signed in it can popup anytime..
Apr 28, 2008 | Microsoft Office Outlook 2003 for PC
Hi :) plese help
remove all external devices and try again does it beep at all?
Jan 03, 2008 | HP OmniBook XE3 Notebook
Symbol MC70 Logo
444 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
