My fridge will no longer make ice. The ice water is dispensing fine, but the freezer does not make ice any more. I can hear the fan running but nothing comes out of the ice maker.
so, how do I adjust the temperature on the ice maker? I see settings for the freezer (the dial indicates 0 to 5 as my options.so, how do I adjust the temperature on the ice maker? I see settings for the freezer (the dial indicates 0 to 5 as my options.
You can't post conmments that contain an email address.
There is a drain line that discharges water from the freezer when the defrost cycle kicks in. It will be a plastic tube that runs from the bottom of the freezer to a tray under the fridge. It has come loose or become plugged I always blow air thru the line and make sure it is not loose. You can also get leakage from an ice maker but this problem will usually show up as ice formingin the freezer first. good luck
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
This could be a bad water valve for dispenser on back of fridge or poor connection in the dispenser control. If you could get me the model number I will be able to help you better.
Look at following areas for the model number
Beneath Or Inside Food Compartment On Cabinet Frame
how do I set it to 12* F?
