Question about Neff K4664 Top Freezer Refrigerator
Neff fridge freezer K4664 broken door handle
I have ther replacement door handle and closing clip for the freezer compartment of my Neff K4664 but unfortunately cannot work out how to attach them to the door. Any help with instructions on how to do this would be great. Thanks
  • 3 Answers
Go and find your frig paper work there are areas with parts and how to order them
Posted on May 13, 2009
Neff fridge/freezer feels hot down centre between the fridge and freezer compartments, making the door see feel hot too
Check your condenser fan motor for proper operation. It is located beside compressor.
Aug 28, 2017 | Neff Refrigerators
My Neff fridge (K4316X1/GB) door does not close tightly on it's own and so does not seal properly unless I press it home
Try the following:
  1. Make sure there is nothing sticking out the fridge what could keep the door from shutting;
  2. Take a good look at the hinges and perhaps clean them or lubricate them (using Teflon spray);
  3. There is a white rubber strip all around containing the magnet with which the door should seal itself. Clean this rubber strip and the surface of the fridge it lands on;
  4. Make sure the fridge is level.
May 31, 2014 | Neff K4664 Top Freezer Refrigerator
Now fridge comes on off every few seconds
The problem sounds like a Start Relay (item 3) mounted on the side of the compressor. Sounds like you are in The UK so call someone at 0844 892 8989 or go to their website HERE The problem can also be related to a defective run or start capacitor (item 10) and it is important that you unplug the power sourse until you have the refrigerator fixed, Sea Breezebcf565b6-47b0-41f1-a143-433ee008bc43.png
Dec 18, 2013 | Neff K4664 Top Freezer Refrigerator
Water accumulates underneath freezer Neff k4664
I've found this when the door seals aren't sealing correctly and also I have seen it when the rear panel of the freezer has moved out of place.
Jul 10, 2013 | Refrigerators
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
I have a large Neff refrigerator with a small freezer compartment at the top (the model no is not on the booklet or the fridge) the freezer door is broken - can i get a replacement? thank you Paul...
Hello Paul,
Try looking on ebay for a second hand or spares repair model.
Also try some of the refurb places where the cosmetic returns get sent with minor damage or faulty components.
PS:any chance you have fitting instructions for an integrated K4664 model ?
Mine came with no instructions how to reverse the door and fit to the wooden kitchen doors so and cant find any on the Neff website.
Thanks
I
PS:
Mar 01, 2009 | Neff K4664 Top Freezer Refrigerator
MSD2456DE - fridge side warm and back panels on freezer icing up. Have defrosted and checked the adaptive defrost control board by shorting L1 and Test - click sound was heard. Believe it to be the...
Forcing the frig into a defrost cycle may not solve this problem long term. The old fridgs had a sliding door which bled cold air from the freezer into the fresh food compartment which you simply adjusted to keep your fresh food compartment at more or less the proper temperature. This simple manually operated sliding door has now been replaced by a motor actuated sliding door that is controlled by the fresh food compartment thermostat. On Whirlpool side by side fridges, the door has, for some reason, been designed so that the sliding door itself will shear or break if the door encounters an obstruction such as ice in the sliding track. Those geniuses designed it so that the door will always fail in the CLOSED position. This means that if this door breaks, the door letting cold air from the freezer into the fresh food compartment will stay closed and not permit any cold air to enter the fresh food compartment and all your food will spoil. The stupid fridge, will continue to run and run because the thermostat in the fresh food compartment will continually call for more cold air, which is just not available due to the broken door. Eventually, the freezer coils will completely ice up and you will see frost on the outside of the panels that cover the coils. If the door is broken, defrosting the freezer will NOT result in any cooling of the fresh food compartment because the door is closed. To check, use a mirror to see if the door is open. The door is typically on the upper back corner of the fresh food compartment on the freezer side. It will have louvers on it. Using a mirror and a flashlight, you should be able to see if the door is open. If it is closed, using a small screwdriver, you should be able to move it open (unless it's iced up). If you can easily move it open with the screwdriver, the door is definitely broken. At this point you have two alternatives. One is to replace the unit and be very careful about too frequent door openings and overloading the frig with food that is warmer than room temperature. These motor controlled units are not cheap. I should know having bought three of them before getting smarter. The other alternative is to attempt to rebuild and/or repair the sliding door assembly. Dis-assembly is accomplished by carefully cutting off the styrofoam front with a box cutter or something similar. This will expose the door and motor assembly. You can either try and glue another piece of plastic where the readily identifiable broken piece was, or attempt to fabricate a whole new door from a suitable piece of plastic. In any case, finish the job by applying lots of silicone lubricant to the door and door tracks to keep it from sticking again. Simply taping on the styrofoam front is good enough till the next time. I hope this helps you with your problem.
Jul 14, 2008 | Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Neff K4664 Top Freezer Refrigerator Logo
498 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
