Question about Brother IntelliFAX 2800 Laser Fax
Will not receive fax Will not send fax Will not copy Has error Message 76 on monitor
  • 58 Answers
Machine error 76 is a bad fuser lamp.Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Posted on May 13, 2009
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
It's not sending or receiving faxes, but line is working
May I know what exactly the model that you have?
Initially, first check the settings of the machine if it was set to tel/fax or fax settings. Check if there was an error message appear on the unit or better to print out a copy of the fax transmission status. Fax machine will print out a copy of the transmission if it has a problem or it has a communication error on the line or in the other side whose receiving the a fax.
Kindly update me again here.
micro
Jul 28, 2009 | Canon FAXPHONE L80 Laser
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Brother mfc 8220 gives error message check original but no paper jam exists.
I assume you're getting this error when sending a fax?
Check original is not a paper jam error. This can happen in the winter due to bad noise on the phone lines. When you send a fax, you can get this result from the receiving machine due to noise. The receiving unit will transmit the error back to the sending unit.
The unit is basically asking you to check the quality of the original document. 90% of the time, there is no problem and the receiving unit actually got a good copy. However, sometimes due to noise on the line the receiving unit will get a poor copy of the fax. In this case the fax should be resent. Of course, since there is no way for you to determine how good the copy is at the receiving unit, in most instances you will have to resend the fax to make sure it goes though.
If, however, you are getting this message while copying (very unlikely) you can do a simple test of the document scanner that should reassure you that there is no serious fault, or pinpoint the actual fault.
Press the following key sequence within 2 seconds: MENU, *, 2, 8, 6, 4. If your unit has a FUNCTION key, use it in place of the MENU key. This should take you to maintenance mode. The display should say MAINTENANCE and all the lights should be flashing. If not, try unplugging the unit, press and hold either the MENU key or the FUNCTION key (depending on which your unit has) and plug the machine back in. This will also take you to maintenance mode.
Now, just press 5 5. This is the scanner area setting command, and if there is any problem with your scanner it will show up here as an error. If there is no fault with the scanner, the unit should return to maintenance mode in a moment. Once done, press 9 9 to exit maintemance mode.
If you are constantly having this error, get a phone repairman in to test your fax line.
Feb 06, 2009 | Brother MFC-8220 Fax
CAN NOT FAX
Hade the same problem it is the main board. We do not get it any more in Namibia. hade sume scrap. If you make a copy do it work?
Nov 12, 2008 | Samsung SF-5100 Plain Paper Laser Fax
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Brother IntelliFAX 2800 Laser Fax Logo
317 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
