Question about HP Photosmart C6100 All-In-One Printer
Memory card error when using sd card to download pictures
When I insert the sd car dinto the sd slot on the right, it takes a second to try to read the card then gives me a memory card error, any suggestions?
  • minard7 May 13, 2009
    4gb, thanks
    Genius:
  • 1,447 Answers
Hi
Whats the memory size of your SD card? this printer only support 1gb card.
Thanks for using Fixya
Posted on May 13, 2009
GT-S3670 trying to download photos onto my computer using san disk
Hello there,
If the scan disk already have the photo on it, then it is easy to download pictures from it to your computer, all you need to do so is a scan disk trans flash adapter also known as the memory card reader. You will insert your memory card into the scan disk if it is the small memory card. then you connect the scan disk into the computer through the SD slot on the computer and then the computer will read its drivers and then you can open file to view folders on the memory card. from there you will be able to transfer your pictures to the computer.
If your computer does not have the SD slot, then you can use the USB type of memory card reader to carry out the operation.
Thank you for using fixya.
Caseytech
Jun 27, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
My camera wont read memory cards anymore. It was working just fine, then the next picture I tried taking it said "memory card error" and the memory card works in other cameras, and my camera turns on and I...
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 29, 2010 | Canon PowerShot A610 Digital Camera
I cannot delete pictures it just reads card locked
Hello
Kind regards
Andrea
May 20, 2010 | Canon PowerShot A480 Digital Camera
I insert a sd/mmc card in the slotwhich is same as
Sounds like the drivers might be missing which is why there is no response.
Depending on which operating system your running on the laptop will determine what file you download.
Go to this page:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=VOS_N_1500&os=WLH&osl=en&catid=&impid=
Choose your operating system, either XP or Vista and then under where it says chipset choose Ricoh Driver and download now. choose download by internet browser. Save it to the desktop if possible and then run the file so it installs.
If you go thru installing the drivrr and the card is still not being read by the laptop then the motherboard is bad.
Aug 22, 2009 | Dell Vostro 1500 Notebook
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Reads card error or turns off once i insert memory card
Hello
Kind regards
Andrea
May 15, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
SD memory card will not format in a Samsung Digimax 301.
I own a samsungDigimax 301, 3.2 mpi camera. When I inserted an SD card in the slot, the screen read " card error". Could you guide me as to dealing with this problem so that I may use the camera to take pictures this weekend? Thanks. Mathew.
Mar 22, 2009 | Samsung Digimax 301 Digital Camera
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6100 All-In-One Printer Logo
585 people viewed this question
Seeker5211
Seeker5211
