Question about K-Tec Kitchenetics K2 Stand Mixer
K-tec elite mixer
When I set my speed (set #4) it will run only a few seconds at a very high speed and then cuts off. It then gives a message of "L" in the speed window and then "OAd" in the main window.   No matter what speed I put it on it does the same.  I have had this model for about 15-20 years and have never had any problems with it.  Please help - would hate to have to buy a new one right now
    Problem Solver:
  • 10 Answers
The company handles these as Blendtec now. The web site is at http://www.blendtec.com/default.aspx Maybe this will help:
Customer service and sales are available from 8:00 am to 5:30 pm (MST) M-F.
Phone
Toll Free: 800-253-6383
Local: 801-222-0888
Fax: 801-805-8585
Posted on Feb 09, 2008
The speeds 1-4 on my kitchenaid 5qt mixer dont turn on and the other speeds setting are all the same speed
The solution will probably be under the back cover. Are the switch contacts touching at speed 1? Are all the wires secure on the black control plate? Has anyone been fiddling about with the speed control adjustments? Possibly the small 4 wire PCB above the black control plate is unwell although normally it would give completely dead or every speed high speed.
Jan 10, 2017 | KitchenAid Food Mixers
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
I have a KA k45ss and it is stuck on high speed only
You need to adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 28, 2011 | KitchenAid K45SS Classic Stand Mixer
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 14, 2011 | KitchenAid K45SS Classic Stand Mixer
My wife's Kitchen Aid Artisan 325W mixer has no high end speed. I tried a new set of brushes with no change. Then starting on speed 1 to 2 and from 2 to 4 you get a nice speed increase the speed the...
You need to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 02, 2011 | KitchenAid Classic Stand Mixer
Seemingly well maintained H600 mixer only runs in reverse...
whoever wired the mixer in , hopefully 3-phase made a mistake on the incoming pwr to term block or the contactor switch any 2 leads this should reverse rotation of the mixer
Nov 04, 2009 | Hobart H600 Stand Mixer
High speed stir setting
There are several things that regulate the speed, we will assume that the adjustment has not been messed about with. If the governor on the motor armature that presses against the underside of the square black speed control plate at the back has not flown apart then I would replace the small pcb (phase board) on the top under the back cover. One screw and 4 wires hold it on.
Jun 22, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
Motor runs only at slow speed, higher speed buttons still run at slow
Phone
Local: 801-222-0888
Fax: 801-805-8585
Jan 10, 2007 | K-Tec Kitchenetics K2 Stand Mixer
K-Tec Kitchenetics K2 Stand Mixer Logo
248 people viewed this question
Top K-Tec Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a K-Tec Food Mixer Expert? Answer questions, earn points and help others
