Question about Dryers
Dryer won't start when start button is depressed
  • 460 Answers
To better assist you I need the model n serial #.
Thank you
Posted on May 13, 2009
Whirlpool cabrio dryer has power but won't start
You may have a burnt out terminal block or start switch.
May 12, 2012 | Whirlpool WGD6400S Gas Dryer
My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
Won"t start when button is
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 16, 2011 | GE DCVH515EFWW Electric Dryer
Kenmore 90 series dryer, the button to turn it on won't stay depressed unless you stand there and hold it down. is there a part i can get for it to fix it or should i just get a new dryer?
heatman101
Aug 11, 2011 | Dryers
Is there a reset button on a Maytag electric dryer purchased in 2000? Power is coming into the dryer, pushing the start button has no effect.
check the switch itself ,, you can do this with a meter and checking for continuity when the button is depressed, also check the door safety switch,, it won't run if this switch is defective,, you can check this one the same way , or just locate the connection, and add a jumper wire, to see if the machine starts
Aug 10, 2011 | Maytag Dryers
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryers Logo
Top Dryers Experts
