Question about Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD Television
No audio I have no audio in input 6
Try going to HDMI Setup under the option menu. You should find an "audio select" option. Choose "analog".
Posted on May 08, 2008
SOURCE:
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    No Audio
    good day sir! are you sure your cables are in good condition?
    Oct 14, 2007 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
    Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
    configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
    make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
    Mar 13, 2010 | Yamaha HTR-5540 Receiver
    Have digital feed connected (white, red, yellow) to DVD connections 6 & 13. Get picture but no sound. Sound is OK on VID1 input from satelite. Any ideas?
    so you have the yellow out from dvd player to yellow in on the receiver (composite video) and the red and white out from dvd player to red and white in on the receiver (right and left audio channel) . you can also plug in the orange rca (digital coaxial audio) go to your menu on the Haman Kardon receiver and make sure you select the right audio input. mine is a Harman Kardon AVR146 push th osd (on screen display) on the remote. go ti the input setup and select the appropriate audio input
    Dec 05, 2009 | Harman Kardon AVR 320 Receiver
    I change Component Cable Video & Audio 6 cables
    I might sound stupid but Double check that you`ve connected the correct connectors as in All Inputs plugs being used or All outputs plugs being used. If you have one of these leads with 6 connectors on one lead, (Audio Input L+R, Video Input, Audio Output L+R, Video Output) You need to make sure that if you get sound from the audio input plugs, then you must use the video input plug and vice verse. Ian
    Jul 22, 2009 | Panasonic PV-D4732 DVD Player / VCR Combo
    No sound from the speakers?
    Mute button engaged? Be sure you have a audio input source, cycle through the different inputs ie,Tuner, DVD, Tape etc
    Feb 17, 2009 | Kenwood VR8050 Audio/Video Receiver 100...
    How to play dts/dolby digital on HK AVR5
    I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
    Feb 08, 2009 | Harman Kardon AVR 100
    Connection of Panasonic DVD Burner to San Sui Surround Amp.
    cant be done, the dvd wont record in surround. you could try a digital TOS, optical audio path and that may do what you need, usually the digital is an orange single input. TOS is the square one that looks like a little bulb on the end.
    Charles
    Jan 05, 2009 | Audio Players & Recorders
    No audio input from video modes
    First of all, there is no audio information on the video lines. These are typically used together with the audio lines to complete the interface between the source(TV, DVD,VCR,etc) and your receiver...accordianman
    Jul 02, 2006 | Yamaha RX-V630 Receiver
    Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD Television Logo
    73 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
