Question about Mitsubishi WS-55908 55" Rear Projection Television
No Turn On
When pressing the power button on the remote or the front of the set I get no response. No relay click. Checked the fuse on the switching power supply and that is OK. I do messure 120V at the supply.
  • 1,694 Answers
Re: No Turn On
Check all the fuse devices--most are soldered-in pico fuses in the power supply circuitry. They range in value from 2 amp to 5 amp or more.They are usually a light brownish color.
Let me know what you find....T.
Posted on Oct 20, 2007
0 characters
3 Points
How do I reset Sony Wega KDF-60XS955
SELECTED PRODUCT: KDF60XS955 (change your search)
How to reset the television to the original factory settings.
Article ID: 42994 ' Last Updated: 08/15/2015
WARNING: FOR LCD AND PLASMA TELEVISIONS: This procedure will reset the video calibration settings of the TV. If you paid to have your TV screen specially calibrated, you may want to first try performing a power reset instead. Otherwise, any special calibration settings will be lost.
A Video Tutorial is available with information about this topic.IMPORTANT:
  • The supplied remote control is necessary to perform this procedure. Then be sure to point the remote control towards the front and center of the television.
  • If lights on the front of the TV are blinking or flashing, follow the steps in this answer.
  1. Unplug the TV power cord from the electrical outlet.
  2. Allow the TV to remain without power for one minute.
  3. Plug the power cord back into the electrical outlet.NOTE: The TV should turn on automatically. If it does not, turn it on.
  4. Wait approximately 40 seconds for the TV to completely start up.
  5. On the TV remote control, press and hold the UP ARROW button.
  6. While holding the UP ARROW button, press and release the POWER button on the TV set. NOTES:
    • The TV may turn off and then back on.
    • The button may be on the front, top or side of the TV. If your TV has an Energy Saving switch, be sure to press the POWER button rather than the Energy Saving switch.
  7. Release the UP ARROW button.NOTE: The initial setup screen displays if the above procedures were performed correctly.
  8. Follow the on-screen instructions to complete the initial setup.
IMPORTANT: If the reset did not complete successfully, disconnect all devices from the TV and turn off or disable the network connection the repeat these steps.
Sep 24, 2015 | Sony Projection Televisions
Tv power (redlight will come on powering the TV then back off
If the model here listed is correct it may be the actual power switch--it like all the front controls is a tiny micro switch--only supposed to work when pressed but can and does fail in this way--
How to prove/disprove this?
Someone needs to remove the front keyboard and unsolder that 2 pin switch---remote will with the board back still turn set on.
If it works that way either just use the remote or search for the keyboard and replace if can find one.
Only other issue possible is the microprocessor in the set could be bad and we do not want that-----both the front buttons on set and the remote go to the same place inside the set but the keyboard has priority over the remote.
If power button bad, button on the remote will not stop or correct this.
Apr 22, 2012 | Hitachi 53SWX10B 53" Rear Projection...
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Sep 19, 2009 | RCA P52926 52" Rear Projection Television
Bigscreen won't turn on at all- no LED's, no sound/vid, get a relay click though
It might be the relay itself, you sound tech savy have you tried testing the transformer and various other main board componets?
Apr 25, 2009 | Projection Televisions
Won't turn on - except for one cooling fan
thee is a fuse near the power plug-in it's a 6amp 125 v ....make sure you bring the fuse with you..will solve the off problem
Dec 07, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Mitsubishi vs 5075
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Turning on SD-P403 Pioneer projection tv
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Oct 30, 2006 | Pioneer SD-P50A3Q 50" Rear Projection...
Cant get the tv to power up
I'm having the same problem. No power at all, tv was working fine and shut off by itself WS-65517. Please help!
Oct 15, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi WS-55908 55" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
