Question about OKI C5400 Laser Printer
Hpqcxs08dll failed to register
I get the following error trying to install a HP J4580:
hpqcxs08dll failed to register
  • Anonymous May 21, 2009
    This solves my problem in installing the software for HP f4200..
    thanks - lawrence
Go to Run, type regedit than go to hkey_local_machine\software\microsoft\windowsNT\currentversion\svchost right click it with mouse select permissions check full permissions for admins or users (if you aren't admin) . Then try to install. Good Luck
Posted on May 20, 2009
Had to install a new harddrive on my HP computer, while installing the HP J4580 software I had a power failure.....rebooted and uninstalled (using the control panel uninstall) the J4580 software. NOW when...
it's sure that the hp j4580 entries are still existing in the computer if the installation was done with the cd-rom then please do the following steps: insert the cd-rom into the computer do not auto-run the cd go to the hp cd icon in my computer right click on cd icon then click on open then look for folder named util under util right click and open folder ccc then under ccc you will look for a file l3 uninstall or uninstall.l3 right click on it and click on open then disconnect the usb cable from the printer(in case it is a wired installation) go on selecting the files that the uninstaller will show then do not restart then go to the control panel go to add or remove programs remove the hp softwares if exists(hp j4580 required software,hp solution centre,hp imaging device,hp customer participation program,shop for hp supplies,etc.. ) then go the start icon go to the run option enter "regedit" then registry opens up click on h-key local machine select software then select hp printer entires that are highlighted then delete them from the registry restart the computer then download the fresh version of j4580 from hp.com then install the software the issue will be resolved for a software download install: go to the folder where the downloaded version is saved then right click on the software and click on `run then close the folder then go the temp folder by writing the command in the run box %temp% then look for a folder that starts with the name"7z........." open that folder then look for util folder then the steps mentioned above will be done please try this and the issue will be resolved if the issue remains unresolved please revert back
Dec 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
When I try to scan it states no scan options. Once it read no connections but I am able to print from my computer.
No, HP J4580, is not a laser, it is inkjet printer.
You did not state what is your operating system and what is exact error wording. Will try to help with these limited info available, I assume you are using Windows.
Your problem indicates that you did not installed scanner software for this printer or it was not installed correctly. I would suggest re-installation of the scanner program and drivers if this is the problem. Before you do that please run HP Scanner Diagnostic Program and then follow it's instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02073847&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3645100
If you require further assistance, please do not hesitate to follow this thread, but please provide me with necessary data, what is your Operating System, what is exact error wording.
Aug 06, 2010 | HP OfficeJet J4580 All-In-One Laser...
I LOST MY Hp OFFICEJET J4580 ALL IN ONE PRINTER DRIVER CD. SO THAT I CAN NOT INSTALL MY Hp OFFICEJET J4580 PRINTER IN MY ANOTHER COMPUTER. SO I WANT TO DOWNLOAD THE DRIVER.
You can download the drivers for any of your HP products from HP's support site (www.support.hp.com)
For your HP J4580 AIO officejet printer you can download the driver from the following link by selecting your Operating system.
Driver for HP J4580 AIO officejet
Thank you for choosing Fixya
May 27, 2010 | HP OfficeJet J4580 All-In-One Laser...
J4580 OfficeJet All In One Printer Laser: failing to install my printer software...
I would like to assist you.
Can you please get back to me with the following information
* Error Message
* Connection Type
* Operating System of the computer
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
I am trying to install the printer driver and the error message says failed to install printer driver, error
please uninstall it forcely by perfect uninstaller.Then delete all hp related folder from programe files.also try to install it after remove ur antivirus
Sep 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Vista Shuts down with hp officejet j4580
Disable all the startup items and your security software and firewall. Then try installing the printer. If you still have the same problem try installing the printer by connecting to a different USB port. You can also uninstall all the USB port from device manager. restart the computer and then install the printer.
Thanks
Nov 14, 2008 | HP OfficeJet J4580 All-In-One Laser...
Error with hp j4580
Uninstall the printer and software.
Download the updated softweware and the driver for your current OS, Reinstall the new downloaded driver when installing the printer via windows control panel.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3645100&lc=en&cc=us&dlc=en〈=en&cc=us
Nov 03, 2008 | HP OfficeJet J4580 All-In-One Laser...
Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
OKI C5400 Laser Printer Logo
1,402 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
