Question about Garden
Ariens model 9604600, back wheels remain locked when trying to push and no lever on back to disengage
    Problem Solver:
  • 10 Answers
The rear wheel is operating on a differential that is jambed up a tad. Make sure you don't have the brakes on (duh!), lift the rear end up and try to turn one of the wheels. but be sure to leave one of the drive wheels on the ground. If no locking lever is being engaged, you have an obstruction in the differential housing (it could be a pin, bolt or something sneaky you kicked up when you ran it). The gaskets could be saved if you take the time to carefully take the housing apart. Grab yourself a decent trouble light and get to the bottom of this so yer ol' Lady can get off your case about neglecting your chores (sorry, bad day for one of us). Pretty simple and straight forward, use the Force, clear the obstruction and button it back together, enjoy. Hope I could give you some worthwhile "atta-boys" and also hope you can feel confident about this simple job. You can do this!
Posted on May 13, 2009
Wheels are locked when trying to push it forward with engine shut off.
There should be a release to disengage the drive system so you can push it when not running. On my Cub Cadet it is on the back above the hitch. It is a simple lever that I pull out and push up to disengage. Has to be something similar on the toro.
May 02, 2016 | Toro Lawn Mower. 22 in. Personal Pace with...
My ariens 20hp 46" wont go forward or reverse
Look for a small disengage lever or sliding control. This is to disengage the drive so machine can be pushed without having to start the engine. It will usually be at the rear and low down, maybe covered by catcher if rear mounted.
Sep 28, 2014 | Garden
Transmission by pass will not reengage
If you are pulling a lever(s) to do this, the pin the connects the lever to the hydro pump could have come lose. Some are fastened together with a removable pin. Check there first.
Apr 11, 2014 | Ariens Garden
Ariens model 936038, blade not disengage After done with the front yard work, I pulled back the lever controlling the engage/disengage, nothing happed. The blade can't be disengaged. The cable is...
You may have debris or corrosion interfering with the operation of the deck. It may be necessary to remove the deck to get a good look at the tensioning mechanism of the deck.
Jul 11, 2011 | Garden
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
Stuck in four wheel in front tire only.
If Jeep is equip with push button 4x4 try this.
If you are stuck in four wheel drive disengage four wheel try backing it up 10ft to re aline transfercase gears.( Also linkage under truck maybe stuck.)
If Jeep is equip with lever on floor.
This one is a common problem lever on floor becomes stuck and won't let you disengage it. Have to Spray linkage with WD-40 or some kind of penetrating spray under truck where the linkage comes out of the floorand goes to the transfercase.
(Floor lever, Its tuff to get it to release I know I went through the same problem on my truck I had push it into 2wheel by using my leg.)
Mar 23, 2009 | 1995 Jeep Grand Cherokee
How to engage 4 wheel drive
to engage pull lever back in to 4H and move truck forward 5 or 6 feet then back up a hair the auto locking hubs on the 88-2000 are all like this for 4L put truck in neutral and push lever all the way forward then repeat the moving of the truck to disengage put back in 2H and back up 6- 10 feet and that should disengage going in and out of low range you must have the truck in neutral or you will damage the transfer case
Nov 15, 2008 | 1996 Chevrolet Crew Cab
Garden Logo
252 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
