Question about Optoma H56 Multimedia Projector
Optoma H56 - turns off just after start up.
I have a Maxx Maverick projector which is a rebadged Optoma H56. The projector is turning off after start up. The projector starts up fine and runs for about 2min then shuts down.
I tried it a few more times and it shut downs after 30sec now.
The projector is roof mounted and has been in use for 3yrs.
thanks for the answers
  • 3 more comments
  • Anonymous Nov 21, 2007
    I have a sahara projector which starts up fine but after a few seconds just fades to black then the fan comes on
  • jpobie Dec 09, 2007
    My H56A shuts off after a few minutes. Ceiling mounted, in use for 3+ years
  • JTBII Jan 02, 2008
    I have a Maxx Maverick projector and it shuts down automatically after a few minutes of use.  I have used this projector for several years without any problems.  The bulb still has at least 1000 hours of use left.  Once it shuts down, there are no lights indicating that there is temp problem.  There is nothing in the manual relating to troubleshooting this issue.
  • Oranje Jan 06, 2008
    I have the same problem. The projector cycles on, picture goes to black and shuts off. I have maybe 500 hours on this bulb. I have tried disconnecting power, reconnecting cables etc.
  • judsouza27 Aug 09, 2008
    same problem with my H6 Optoma. It has been in use for 4 years and this is he first time I have experienced this problem. Lam has about 900 hours left.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Posted on Jun 06, 2009
You have a blown bulb. I have the same projector and it had the same problem. The bulb is blown replace it and you should be fine.
If you are not sure of my solution you need to know that your projector will look like it is starting up and the bulb will partially light up but never come up to full brightness, then the projector will shut down. This will happen over and over until it just gets to the point it just turns on (the fan comes on and then about 30 - 60 seconds later the fan turns off.
Replace the bulb and you should be fine.
Been there done that!
Posted on Sep 25, 2008
I had this problem as well a year ago, but the solution was in reverse. I mounted it on the ceiling to "solve" the problem. But, no matter what I did, it would not run on desktop. Now I am experiencing the same problem from the ceiling mount position, and it still does not work on desktop. So it looks like I will have to take it to a repair shop to test for this mysterious short.
Posted on Aug 23, 2008
I had this problem too. I googled for similar problems and found a solution that worked for me. My projector is ceiling mounted upside down. When I turned the projector over so that it was right side up and started it, it worked fine. I ran it this way for about 1/2 hour then reinstalled it upside down. Problem solved. I suspect there is a short somewhere that only occurs when the projector is upside down. I had tried everything else first, i.e. reinstalling the bulb, cleaning with air etc.
Posted on Jan 06, 2008
I need new color wheel for Optoma H56
Hi Optoma MD,
Do you have the 70.81r26gr01 color wheel on stock?
can you send me an email: j.hogenhout@home.nl
With kind regards,
Joep Hogenhout
Aug 13, 2010 | Optoma H56 Multimedia Projector
OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Mar 05, 2010 | Optoma HD70 DLP Projector
I have an optima h56 and when I turn on the power it acts as though it is trying to come on and then shuts down, and I do not see the light coming on from the bulb.
it's either the colorwheel, or the ballast. do you hear a high-pitched whir? if yes, the problem is the ballast. if no, the colorwheel.
Nov 06, 2009 | Optoma H56 Multimedia Projector
Reset bulb hour counter.
hi,this should be in your menu and should b under lamp reset
Apr 25, 2009 | Optoma HD65 DLP Projector
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Apr 15, 2009 | Optoma H56 Multimedia Projector
Cooling fan problem projector
I have a similar issue though mine isn't quite as extreme as yours. Got a couple things you can do.
1. clean out the projector with compressed air. You might have dust building up on components that is trapping heat.
2. Your fan might be burning out. Needs to be replaced. I'm still working on trying to figure out what tipe of fan it needs.
3. The temperature sensor might be going bad. This one is less likely and most complex to solve as it depends on how the system measures the temp. I haven't checked in detail yet.
4. Replace the whole unit or send it in for repair. Both options will be costly...
Jan 01, 2009 | Optoma H56 Multimedia Projector
Projector will not turn on no fan no light
Hi!
Here is a link to the "Troubleshooting" part of the manual to Optoma H56 Projector. Hope it will help!
Troubleshooting Optoma 56 User Manual Page 27 of 32
Jan 04, 2018 | Optoma H56 Multimedia Projector
"Sunshine" Glare on faces and other bright areas
Hi there
What make and model is this Projector ?
Mar 23, 2008 | Optoma H56 Multimedia Projector
Dramatic increase in fan noise
Hi there
If you place your hand on the machine and you can actually feel the vibration , you might be looking at a faulty Colourwheel.
If not , try cleaning the fans by blowing it out. If the problem still occurs you might have to replace the fans.
Dec 05, 2007 | Optoma H56 Multimedia Projector
Upside down projection
Download the latest display driver for your video card. If you are using ATI vc's then download and install the Catalyst Application which will allow you to rotate the screen orientation .
Jun 20, 2007 | Optoma H56 Multimedia Projector
Optoma H56 Multimedia Projector Logo
1,939 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
