Question about Acer Aspire 5580-6707 Notebook
Acer laptop aspire 5583NWXMi is not working properly
I m having problem with my acer notebook:
display is not proper (its kinda widened)
not able to use my GPRS thru blueooth (it says modem not detected) where as its working ok with USB data cable
Acer aspire 3642 no display
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 13, 2012 | Acer Aspire 9300-3642 Notebook
Hello, I've a acer aspire 7738, with windows 7 The problem I have is that my display isn't working right. The pictures have al small dots in them. The text is oké, but the pictures are not...
Right clic on your screen
Then select the proper Display (Mobile PC Display)
Select the proper Resolution (Usally Recommended by Windows
Select the orientation (Should be Landscape)
And reboot if necessary
Sep 24, 2017 | Acer Aspire 7738-6719 Notebook
Ny acer aspire one only shows blank screen
The backlight have went out on your screen. I had this happen on an old laptop2_bing.gif I was messing with. Check the link below for some tips.
DARK SCREEN If you shine a light on the screen, can you somewhat see the screen? Does the laptop power up properly? (can you hear it running?) Hook up an external monitor to your laptop, does the external display properly?
Mar 01, 2010 | Acer Aspire One PC Notebook
I have an Acer aspire 1640, the screen remains blank
Try to connect the laptop using and external monitor if the external worked the problem is with the laptop. If not try to reseat the memory module also.
ERNZ
Feb 03, 2010 | Acer Aspire 1640Z Notebook
Bluetooth install
hai dude
you need to instal proper driver on it then it will be work properly this is the link 4 u
http://www.notebook-driver.com/laptops-information/acer-aspire-4930-notebook-technical-specifications/
Mar 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Sound driver software downloading for Acer Aspire 5583NWXMi
before formatting
in device manager write down
display
network
audio
and video drivers
Feb 15, 2009 | Acer AOpen AW 200 Sound Card
Driver audio cannot support headphones,please help for the driver
Hi
Restart the system and then try it...
If its not work means then check ur audio driver is working properly...
again its not work means try to reinstall the software...
thank you
Dec 02, 2008 | Acer Computers & Internet
Agp can't work properly...
Try setting your screen display a little bit lower than the current setting.
Sep 02, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire 5580-6707 Notebook Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
