Question about SanDisk Sansa e130 MP3 Player
Headphones my headphones won't work. i mean right one is working fime, but left one doesn't. when i've tried the other ones, sam thing. All headphons were new and they work just fine when i test them on my computer. How do i fix it?
  • Ocived Nov 04, 2007
    Hello, I have the same poblem, man this is all ove the help sites. Is Sandisc doing anything about it I bought 2 at the same time and both of them are having the same adio problems plays only on 1 speaker . If I apply uneven pressure to earbud plug it corrects itself. Are the connections on the female part worn? Any fixes Thank You
    Ocived@aol.com
  • 626 Answers
The headphone jack is loose from the circuit board.
If its less than 1 year old, SanDisk will replace it.
Otherwise, you can take it to a electronics repair shop, or someone who knows how to solder.
Best of Luck.
Posted on Oct 14, 2007
Headphones not working
try geting a new jack if not bye a now wone
Jul 25, 2012 | Harman Kardon AVR 7000
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
Left speaker on my Koss SB45 Headset isn't working unless I tilt to the right or turn around.
Have a look at my tip on headphone problems. Just click my user name to find it.
Jan 08, 2012 | Koss SB45 Headphones
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
So basically my left earbud doesnt work anymore, I dont get how this is possible, I bought them two weeks, one day I go use and its not working anymore, the right one works perfectly fine, i really need...
First try them in a different device,
if they still don't work properly - Your headphones are broken.
This can occur if they are pulled too hard - the slim guage wires that they use in these things can come apart pretty simply. My advice is to take them back and get new ones :)
May 11, 2011 | JVC HA-F120 Consumer Headphones
My lenovo y 430 has no sound for hedset & subwoofer doesn`t work. ... and right speaker works but left one doesn`t what should i do?
Make sure that the correct playback device is set as default in sound properties.
If all is well there then you could try a pair of headphones to see if the sound is working.
If headphones work ok then it is down to your built in speakers, not much you can do unfortunatly unless you are still under warentee
Jul 10, 2010 | Lenovo Tablets & eReaders
No sound in right earbud?
sounds like your 3.5mm jack (headphone jack) s broken. try getting a new one on ebay. if you are not confident opening your ipod, find a handy friend to do it for you
Aug 17, 2009 | Apple iPod MA446LL/A MP3 Player
I lost the sound on the right ear of my bose around-ear head phones and I checked the lines and nothing is cut, the left ear is working perfectly. Please help!
This may be your headphone jack (what you use to connect it to your ipod or speakers ect.). check the connection there, and if you see the wire became loose near it, that is most likely the problem. You can fix it! With a new headphone jack (available at the Source or Radioshack or other stores like that), and with some manual soldering (it's not too hard, I fixed my myself and I havn't soldered before.) you'll get those headphone to be as good as new. here are the steps to fix this problem.
1. cut your old headphone ******** and strip the wires. you should see two wires; one copper wire and one coloured wire (green or Red) on each cord. there is a total of 4 wires, two per cord.
2. Tin coat the wires. this means to burn the wires a bit (with the soldering iron) and put solder over them. this gets rid of the coating that is on the wires to stop them from shorting out in the cord and helps conductivity when soldering them onto your headphone jack.
3. there should be three holes on your new headphone jack. there should be two prongs left and right of the part you plug into the machine, and there should be one connected to the part that holds the wires once done.
4. connect the coloured wires (red and green) to the left and right prongs of the new jack and secure with solder. These are called the live (or hot) wires because they are the ones that send the signal that makes the sound.
5. connect both of the copper wires to the other hole and secure with solder. these wire are both ground wires, which are very important.
6. by the end, you should have connected four wires. two to the seperate prongs, and two to the third ground hole.
7. test your connection by trying to use your headphones. if it does not work (which may happen, don't get discouraged!) check your soldering. if it is touching any metal it shouldn't be, that means you have created a short circuit. simply burn off the solder (with the soldering iron) and try again.
8. keep trying until you get sound. good luck!
9. Once you get sound, you may want to secure the soldering job. you can either use two part epoxy and put this over your work, or you can tie a knot before you put the cover on you headphone jack. either will work just fine. Also, there sometimes are two metal protrusions that you can bend with plyers to help hold your chord in place.
10. enjoy your fixed, good as new headphones! Enoy hope this helped.
Bee's
Jun 20, 2009 | Bose Around-Ear Headphones - Silver
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
SanDisk Sansa e130 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
