Question about IBM IntelliStation Z Pro 6223-42U PC Desktop
Problems with Intellistation 6223 Power Supply?
Our Intellistation 6223-6GU workstation, purchased 4 years ago has been powered up for first time, and immediately showed power supply problems, (I believe it has 530 watt AC 120/230 volt power supply). I see from your web pages that this is a continuing problem with Z-Pros. Any source to replace or fix?
  • 696 Answers
As this is the first time powering up, check the 115/230V switch on the back of the machine to ensure it is set properly. Then if you're ok going inside the PC follow each cable to it's connector and make sure all are connected firmly then try to start the pc again. If this doesn't work it's likely a dud.
These power supplies are cut to a funny shape so you do have to replace them via IBM. You can take it to any IBM service center or got to:
http://www-304.ibm.com/shop/americas/content/home/store_IBMPublicUSA/en_US/parts/parts_main.html
check for part exchange discounts and then submit, on the next page it will ask for the IBM part # which will be on a sticker on the power supply. The part is fairly easy to swap out if you're at all handy with a screw driver. If you're not, call the 800 number on the above page and ask them for the closest service center.
Hope this helps FixYa,
Chris
Posted on May 14, 2009
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
My HP D530C does not power on. The power LED flashes 4 times. What is the fault? Pls let me know asap. Thanks.
HP xw6200 Workstation - Diagnostic LED Code: Four Flashes ISSUE: When the workstation is powered on, the front LED might flash red four times, once per second, followed by a two second pause. SOLUTION: The front LED flashing four times is a sign of a power failure. To fix this issue, complete the following steps:
  1. Open the access panel, and check to see if the four-wire power supply cable is properly connected to the system board.
  2. There may be a faulty device. Locate it by removing all devices and then reinstalling them one at a time until the workstation fails. Replace the device causing the failure. Continue adding devices to ensure all are functioning properly.
  3. Verify the power supply functionality, as follows:
    1. Disconnect AC power.
    2. Remove all internal power supply cables from the system board.
    3. Plug in AC power.
      • If the power supply fan spins, and the BIST LED illuminates, then the power supply is good. Replace the system board.
      • If the power supply fan does not spin, or the BIST LED does not illuminate, replace the power supply.
Dec 13, 2011 | HP Compaq d530c PC Desktop
IntelliStation Z Pro 6223-3EU:what memory does it use?
It uses 2GB DDR2 SDRAM memory at the speed of 400 MHz. And supported up 16 GB of memory
Jul 28, 2010 | IBM IntelliStation Z Pro 6223-3EU PC...
What are the compatible BIOS for intellistation Z PRO 6223 work station
Here is the link to your system BIOS tools and updates:
http://www-947.ibm.com/systems/support/supportsite.wss/supportresources?categoryind=5050379&selectedButton.x=12&selectedButton.y=13&selectedButton=category&familyind=5050008&brandind=5000004&osind=5053379&typeind=5178890&modelind=0&matrix=Y&taskind=2
Dec 17, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
With a IBM 6223 can I mix sata and scsi drives in the same machine?
Yes. you can use any mixture of different interfaces a PC. As long as you have the appropriate controller interface to plug the drive into, and your power supply is big enough to support the drive(s) you're using, there should not be a problem.
The only caveat is that if you want to boot from a drive type that is not part of the PC bios, this may not work.
Such as if the bios is so old that it only has IDE and you plug in a SATA or SCSI adapter, it may take some fiddling to make it boot properly. Many interface adapters have their own bios, and sometimes things are not as compatible as they should be.
Oct 21, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Does not see hard drive
configure the bios settings, hdd should be scsi. maybe your current settings is sata or ide. if not work check the scsi controller if have installed driver or compatible to your unit.
Oct 10, 2009 | IBM IntelliStation Z Pro 6223-31U PC...
How to install Adaptec SCSI driver when installing XP -Z Pro 6223
you have to use sata xp cd to intall that driver no need floppy disk.
Aug 19, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM IntelliStation Z Pro 6223-42U PC Desktop Logo
206 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
