Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Frigidaire Gallery washer inner drum off balance
I have a Frigidaire Gallery front load washer. It was recently moved between houses without the moving brackets being put in place. The inner drum now seems "off track", very loud spin cycle. The washer is level and the shock absorbers look fine. The washer does not shake but the inner drum vibrates and shakes like hell in spin mode. Are there rollers in between drums? Tracks? Bearings? Does a person have to remove the outer drum and split the two halves to get at the inner drum...man, I'm up to my neck in this thing.
SOURCE: Loud thumping while spinning
my friend had this happen,apparrently a bearing was leaking then finally broke!
Posted on Aug 23, 2008
docjohn174
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
SOURCE: Need replacement inner and outer
Wrote in German to an appliance repairer in Germany.
Posted on Nov 27, 2008
dh1200s
  • 335 Answers
SOURCE: Looking for replacement bearings for the outer tub
It sounds like you may have to replace the Outer Tub to replace the Outer Tub bearing .....ain't that just peachy.....good job Maytag design team.
If you are the original owner I would press Maytag hard to replace the Outer Tub based on the Outer tub Bearing failure. Their warranty states third thru tenth year Drive Motor, Outer Tub and Sealed Transmission. I’m sure you will need to have a certified Maytag repair service tech certify the failure and fix action required. Why should an Outer Tub bearing replacement cost you $430. Another poor design issue of this machine.
Posted on Sep 26, 2009
  • 29 Answers
SOURCE: on a hotpoint ultima wt741. how does the plastic
2 tubs used on these-one has screw going around the middle of the tub to split in half/the other is a sealed tank which means you have to replace tub-if you have a filter under the front kick strip then its the sealed tub
Posted on Nov 13, 2009
How do I level my frigdaire gallery front load washer
Thank you for your inquiry, friend!
In order to properly balance your Frigidaire washer you would need to seek the help of a professional. Regrettably, this is not a simple DIY job and I would highly recommend reaching out to an expert technician to ensure the repair is correct to prevent future issues. I hope this information helps to some degree. -Matt
Oct 11, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
We recently moved our washer and it has progressively become really loud and shaky during the cycle. On the last load, it didn't drain and my laundry was soaking wet. What do I need to do to balance it?
Had the same problem with my HE5, the washer drum bearing is going bad. The problem with this, is that the bearing is pressed into the drum . This means that you will need a new inner and outer drum. How can you check??? Open the back panel and if you see brown residue or metal shavings , you know it is the axle bearing.
Jan 11, 2011 | Kenmore Elite 45986 Front Load Washer
Front seal not supporting drum, drum flops violently, doesn,t leak. seal wont stay on drum.
it sounds like you may have tub bearing issues or your suspension springs or shocks may be missing or broken. The front seal is just there for sealing, thats its sole purpose.
Basically there is two parts, the inner stainless steel drum and the outer plastic tub housing. Reach inside and see if you can move the inner stainless drum up and down any significant amount? If so the bearings are most likely shot. If its pretty solid but the outer plastic tub moves, its most likely a suspension issue. You can take off the top to get a much better view of the components.
Oct 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Can you replace just the rear bearing on a frigidaire "gallery" series front loading washer without having to replace the rear drum half as well. if so where can i buy just the bearing?
Hi, Welcome to FixYa. I theory...yes it can be done. The problem lyes in 1) finding just the bearing & seal... and 2) the shaft of the inner stainless steel basket is likely going to be badly worn or "scored" as a result of the bearing failing. I always replace the entire assembly, but if the bearing and seal where available seperately it would still require the inner basket and a complete tear-down and just as much labour ( or more likely ) it is less expensive to do the complete assembly. I'll leave that with you, let me know if I can assist you further. Macmarkus :)
Aug 30, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Spin cycle is making loud clunky noise to a frightening degree. Frigidaire Gallery Washer.
The drum inner bearing which holds the drum unit will be damaged kindly replace the bearing along with the washer to get rid of noise
Dec 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Drum is loose, struts maybe? springs?frigidaire gallery front load.
this could be the bearings,if you feel a knocking noise when lifting the inner chrome drum up and down then its the bearings,
Jul 06, 2009 | Frigidaire GSTF1670A Front Load Washer
I have a frigidaire gallery front load washer need help
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
May 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FWT647GHS0 Front Load
you have a bad rear bearing in the rear housing the rear housing is a warrenty part for life on the part but there is parts that should be replaced at the same time expereance guy can do it in about 2 3 hours if not chould be a long hard prosses
Dec 26, 2007 | Frigidaire GSTF1670A Front Load Washer
Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
May 16, 2007 | Frigidaire GLTF1670A Front Load Washer
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
620 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
