Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Frigidaire Model PLHS67EESB4,ice maker just stopped working.
Frigidaire Professional model, PLHS67EESB4, the ice maker was working just fine then after the power breaker was tripped it just stopped making ice. it did have a small amout of ice that it tried to produce but that was it.
SOURCE: Ice maker isn't making ice...
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Posted on May 04, 2008
SOURCE: 550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Posted on Jul 19, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
  • 11 Answers
SOURCE: U-Line sp-18 RV Ice Maker
Allow the unit to dry out for a few more days and see what happens, but it sounds like there's a shorted wire someplace in the unit. I would not put this unit into service until this is found.
www.u-lineservice.com is the mfg website for service, you can find a servicer zip code search at this site
Posted on Dec 23, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
Frigidaire professional ice maker does not work
Would it be possible to provide a model number to the refrigerator so I can see what type of ice maker you have thereby giving you some tests to do? Appliance 911 Sea Breeze
May 08, 2016 | Frigidaire Refrigerators
Ice maker chute not sealing. Ice and frost is building up around the ice maker and the chute door in the freezer door.
Thank you for your post, friend!
It sounds like there could be a possible air leak within your Frigidaire refrigerator. I would check the gasket that goes around your refrigerator. The best way to test this would be to place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket.
If the seal checks out to be fine it could be a possible problem with your dispenser or leak within your icemaker. I would recommend having a professional come out to properly diagnosis your appliance. I hope this information is helpful. -Matt
Oct 06, 2014 | Frigidaire Refrigerators
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
Ice Maker stop working
There are no serviceable parts on that ice maker and it will need to be replaced. Here is the ice maker to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 06, 2013 | Frigidaire Refrigerators
Frigidaire water stopped working...ice maker.dispenser fine
You probably have an obstruction in filter compartment. you should remove filter and inspect o rings etc. or anything that could have clogged it up. The only other thing that could be the cause is a bad water valve. Side by sides have a double water valve. one for water ,one for ice maker. You can check this by having someone flip ice maker arm down so it calls for water and feel water valve as it runs and possibly hear it too. Hope this helps.
Jul 24, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker arm does not move freely.
there is probably a piece of ice caught under one of the harvest fingers, at this stage of the harvest, the ice arm is engaged and will not move freely until the harvest cycle is complete.
Jun 14, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker not making ice
there is a separate solenoid that controls the icemaker its on the back of the fridge on the bottom.
it may have stopped working or the filter is clogged.
its a simple fix but it takes some know how to do so.
Mar 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Ice maker only works for short time
I HAVE THE SAME PROBLEM WITH THE ICE MAKER FRIGIDAIRE FRS22WNC. IF ANYONE HAS AN IDEA HOW TO SOLVE IT PLEASE EMAIL ME TO HYATZFT91@AOL.COM
HIGHLY APPRECIATE IT.
NICK
Sep 07, 2007 | Frigidaire FRS23H7C Side by Side...
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
129 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
