Question about Equator EZ 2512 CEE Front Load Washer / Dryer
Fan belt broken?
I think my fan belt broke yesterday while I was washing some towels. I heard a loud bang and then the drum stopped going around.
The problem now is that I have a load of towels that I need to take to the laundromat to finish washing, and I can't get the door to unlock.
The only thing I can think of doing is to let it run through the cycle until it gets to the part where the pump pumps out the water, then turn it to Reset and see if that does it.
Is this wrong? Will I burn out the motor if I run it without a fan belt on it?
  • 1 more comment
  • MarianB Oct 14, 2007
    Thanks, I'll go and switch it back on. I guess I should find my screwdriver and take off the back cover first.
    Thank you for the reply!
    OK, the belt isn't broken, it just slipped off, apparently. I am trying to put it back on, but I can't make it stretch (I know it's probably not supposed to stretch). I see a hole that would accommodate a hex wrench on the wheel that turns the drum, so I'm going to see if I can loosen that and get the belt to go back on.
  • MarianB Oct 17, 2007
    Thanks, barnsleymick! I talked to my dad on the phone and he told me how to get the belt back on without taking anything apart. I had to drain the tub and take out the wet towels before I could move the pulley though.
    Thank you so much for your help! I don't know how to change the rating on this, or I would.
    Problem solved!
The motor bracket is broke, which allows the motor to "jump" causing the belt to come off.
Posted on Oct 29, 2007
  • 209 Answers
Select a drain only option if the machine has one otherwise ok just let it run,
once the water has drained the door should open, then ask yourself why the belt snapped, which could be an entirely different situation
the only problem you will have is that the drum won't go round, this will not damage the motor or burn it out, if at all possible before doing this, try to remove the remains of the belt
Posted on Oct 14, 2007
  • mick d Oct 15, 2007
    not a wise move, just make it stretch, trust me, ut the bolt back in then put the belt back on, it does stretch, thats what makes it tight
SOURCE:
When spinning on highest spin make very loud noise like brick inside then heard loud bang and noise stopped washer carried on spinning
Hello that sounds like a broken spider that's blotted to the drum what hold the drum to the bearings if one is broken that will do that the banging is when it pop out on a spin it sounds like a brick hitting the back I would be very carefull as it can try and flip the machine if it catch the drum it's not bearings as you said it stopes and it was ok so it's the spider and most drums are sealed units so you can't do any thing ok hope this has helped you
Nov 13, 2015 | Washing Machines
WMA30 Front loader
when a machine gets old it is always normal for the vibration and banging to occur, then, after the vibration it settled down smoothly.this is due to worn fan belt .bearings worn out and the preasure on the spindle.so dont get alarm .but you will soon have to replace the washer as the banging and the vibration will get worse eventually.or change the fan belt.and replace bearings.which can be done by a qualified personel.good luck.
Jun 09, 2007 | Hotpoint WMA30 Front Load Washer
On spin cycle very LOUD noise and some smoke immediately after shutdown. Drum rotates off center of outer drum, and rubbs at only one point in the rotation.
Try Repairclinic.com for drawings. Find the big capacitor, and look at it. If it blew, it would show. You would think a spring broke, the broken one would show. Maybe a shock absorber ruptured?
Nov 27, 2013 | Maytag MAH6700AWW Neptune Front-Load...
Wsher will not spin at end of cycle, tries to and stops. there was a loud bang in the previous load. drum will spin but tight. What to check kenomre 417-44142400
Hi stevensch693,
The loud bang you most likely heard is the capacitor of the motor, it has blown.
Open the washing machine up, look for the following component near the main motor:
You will need to replace this component. Be very carefull when disconnecting it, as it may still give you a nasty shock.
You can find these at any appliance spares shop or even hardware outlet. Note the number on it, if requesting a emplacement - even better, take it with when purchasing one.
Kind Regards
JEDMEEYER1
* If this solution helped you, please accept it
Jul 24, 2011 | Kenmore HE2 Plus Front Load Washer
Loud pop (sounded like a gunshot) during final spin cycle than heard constant noise. Does this sound like a busted bearing or belt? The tumble wheel is now very loose (easy to move and turn inside washing...
if the drum is very easy to turn with no resistance then the belt is likely broken and needs replacing. This is like changing the fan belt on a car where you loosen the bolts on the motor and hinge it towards the drum. Once the belt is in position, lever the motor back away from the drum to tension the belt and tighten the bolts.
Dec 17, 2009 | Frigidaire Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Turned drum by hand, heard loud bang. Drum will not turn anymore. How do I fix it?
your belt probably broke the bang evidentally was the pressure being taken off your belt tensioner when belt gave out take frt cover off then top cover both will need to be off to repl belt anyway if that was it
Jul 13, 2009 | Kenmore Dryers
My dryer drum stopped turning. The dryer will turn on
it does sound like the belt is broken. you will need to access the inside of the dryer by removing the front. they all come apart differently. Make and Model would help me tell you more.
Dec 26, 2008 | Dryers
Boom and Bang Washing Machine
Bed sheets or comforters will often get out of balance in the spin cycle or during the rinse cycle. Throw some towels in there next time at least 5 big ones. They are engineered to take a little of this banging, it should only happen once in a while.
Oct 05, 2007 | Washing Machines
Equator EZ 2512 CEE Front Load Washer / Dryer Logo
100 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
