Question about Frigidaire GLTF2940ES Front Load Washer
My GLTF2940ES Front Load fridgeadire wont fill or drain
It hums during filling proceedure Help!!!!!!!!!!
  • smccaste May 19, 2009
    its all fixed it was the pump trap! underwires candy wrappers etc!!
    Thank you everyone!
    Problem Solver:
  • 9 Answers
Make sure you have water going through your inlet pipes pull the machine out and check while pulling out check they are not getting kinked. if water is going through pipes once removed from machine you have a problem with your inlet valves its unusual for both to go unless your using cold fill only check for calcium build up where you connect your pipe to valve test while pulled out.good luck.
Posted on May 19, 2009
My Electrolux F/Loader won't start filling. I select a wash cycle and start . The screen shows 'filling' but only makes clicking noises.
Thank you for your post, friend!
I see that your Electrolux washer won't fill during the cycle and makes a clicking sound. This clicking sound could come from either the motor or the water valve. In order to locate which component could be causing the issue you may need to disassemble your washer. I would recommend having a professional technician out to properly disassemble the washer to prevent any personal injuries or future issues. I hope this information is helpful to you. -Matt
Apr 17, 2016 | Electrolux Washing Machines
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Kenmore coldspot 106 icemaker working fine but in the last week has started to make a loud buzz/humming sound when filling... is it the Solenoid, water fill valve or the ice maker motor ?
If you think it's only during the fill (20-30 seconds at the end of the cycle), it's probably the fill solenoid. If it were me, I'd let it go a couple of weeks and see if it quiets down on its own. There's nothing harmful about a solenoid humming, and you may find that better is the enemy of good when you wade into trying to fix it.
If you can't live with the noise, I'd suggest replacing the entire valve body and solenoid as a unit - you never know which part may be the source of the problem. It's only 2 water connections and 2 wires. You can buy the part online for $20 or less.
Feb 25, 2018 | Refrigerators
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Fdb126rbs2 fills and drains fine but does not
DO YOU HEAR THE MOTOR START OR HUM AFTER THE WATER FILLS? IF IT RUNS CLEAN YOUR FILTER AROUND THE BOTTOM OF THE LOWER SPRAY ARM INSIDE. LET ME KNOW IF YOU HAVE MORE INFO.
Apr 25, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Doesn't Wash Clothes, But It Rinses Clothes
hello. i can help you.
Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jun 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
2000 jeep grand cherokee limited edition
I don't know of any real proceedure, Just make sure its full and there is no air traped in the system, If there are any bleeders like around the thermostat housing, or any where in the cooling system open them up while you fill it to let any air to excape If not just fill radiator untill your sure you can't get any more in it before you start it.
Apr 04, 2009 | 2000 Jeep Grand Cherokee
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
Humming noise
if you're talking about during fill probably just a noisy valve may or may not be a real concern just a noise if objectionable replace valve
Sep 01, 2008 | Roper RAS8445KQ Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
120 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
