Tried to install new toner on my OKI 5800ldn today and it keeps saying it is empty. I have cleaned the connections, restarted, shook the cartridge and nothing is working. This printer is brand new..I am replacing the starter cartridge.
  • 400 Answers
Does that printer require you to insert a chip?
look in the toner box and see if there was a chip (or a card) that needs to be inserted into the printer.
Posted on May 13, 2009
Ricoh sp811dn toner cartridge is ot detected when replaced
In the back of the machine on the nozzle assembly there is a toner end sensor. It is possible it just needs blowing off clean. Excess toner spillage in that spot prevents the sensor reading correctly. However, if that do not work, it may need new sensor.
Mar 30, 2017 | Ricoh Aficio Office Equipment & Supplies
I need to clean out my Laser printer - OKI OL 400EX
I replenished the empty toner cartridge using the contents of a reduced price (from PCWorld) cx-OKI400l-is cartridge. For this you need a steady hand and a very small, very shiny stainless steel funnel. These are available from a good kitchenware shop. There is a removable cap to the cartridges. I understand one should only use the Toner from a cartridge by the same manufacturer as the printer. My old OKI OL400ex is now working again. I still don't have the answer to: Where does the excess Toner go? Does it fill up the printer drum? Michael UK
Jan 22, 2010 | Office Equipment & Supplies
I´ve got a message on my oki C5510 mfp printer "Failed to get printer information - Check printer". I´ve checked all cables and everything is ok. The toner light and exclamation light staying lit...
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
Nov 08, 2009 | OKI C5510 MFP All-In-One Led Printer
OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
Oct 26, 2009 | OKI C5650n LED Laser Printer
Put in second toner and machine is still saying toner empty
If you are using refilled cartridges those errors are common, Samsung has an eeprom on the cartridge keeping track of usage and you need a new chip from the refillers. If you are using OEM cartridges you need to clean the contacts inside the machine that the cartridge connects to and wipe the contacts on the cartridge before installing, Otherwise a shop repair for the CRUM circuits.
Sep 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Changing the toner cartridge in an oki b4350
Is it a OEM cartridge, which means that its made but the manufacturer of the printer. If it is a refurbished cartridge then it will probably not be "recognized" by the printer and subsequently tell you its low on ink.
Jun 23, 2009 | OKI B4350 Laser Printer
Error Message/Black toner empty
Your printer cartridge chip is damage you change Black toner cartridge
May 28, 2009 | OKI C3400N Single Pass Color Printer
Error message says toner cartridge empty, but it is not empty
I am not certain this procedure will work with your model, but it's worth a try:
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100\%.
Jan 03, 2018 | OKIDATA - 91615001 Printer
Oki C3200n Says Order K Toner after install
Two possible problems:
1. You actually got a partially empty new toner. This has happened to me once.
2. The sensor on the printer is dirty and not seeing the toner. With the toner there is a little wipe that says it is for cleaning the LED. There is an LED sensor that "reads" the presence of the toner. If this is dirty it will think there is no toner cartridge.
Jul 09, 2008 | OKI C3200n Led Printer
OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Aug 24, 2007 | OKI 9800hdn Laser Printer
195 people viewed this question
k24674
jasbo
jasbo
