Question about Amana ACD2232HR Side by Side Refrigerator
Water leaking my amana is leaking water underneath the fridge and the ice maker nor the water dispencer works-do we need a new ice maker or can we just replace something?
  • 6 more comments
  • Fred Giordano Nov 15, 2007
    I have a similar problem with an Amana side-by-side not listed here -- Model ARS2667AC. After reading this post, I pulled out the refrigerator and used a ratchet to remove the metal piece to which the dual water inlet valve is attached. I looked inside and, sure enough, the water line had detached from the "Y" on the valve, leaving water in the bottom of the refrigerator. I dried it and turned off the water. Can you confirm I need to make the same repair? If so, what is the part number, and will the part come with instructions on reconnecting the water line (it almost looks like it broke off)? Thanks.
  • MyRepair Mar 04, 2008
    I need to replace the water valve on my refrigerator but the tube connections are not nuts. Do the water tubes just pull out or what?
  • Anonymous Mar 12, 2014
    ice maker amana leacked water in to frig
    ice maker keaking wTER
    ICE MAKER LEAKING WATER
  • Anonymous Mar 13, 2014
    Ice maker works fine. No water dripping underneath.
  • Anonymous Mar 18, 2014
    water leak from underneath the fridge
  • Anonymous Mar 29, 2014
    We have a frigidaire model FRT18S6A 18.2 cu. ft. refrigerator that leaks intermittently, any ideas? It's not a constant leak. Doesn't appear to be any water between the back of the refrigerator and the wall. The appears to be coming from underneath the refrigerator but doesn't appear to be tied to anything the ice maker is doing. Thanks!
    President:
  • 331 Answers
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
Posted on Oct 15, 2007
Ice maker not working, water dispencer not working
check water line connected with fridge may be closed
Sep 19, 2014 | Amana Refrigerators
ICE MAKER DOES NOT DISPENCE ICE
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Electric GSH25JFX Side by Side...
I have an Amana refridgerator, BRD18V13, and the ice maker stopped making ice. What's wrong?
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Amana Refrigerators
The ice maker stopped working .There is water in the plastic tube in the back of the refridgerator but it only gets to about 3/4 of the way up the tube. The water dispencer stopped working years ago but...
Pour about 1/2 cup of water into ic emaker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure the fridge coils are clean and free of dust , lint , pet hair , etc..
VE6GAR 73 88 99...thumbs up..
Aug 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana refigator
If the dual water valve(you'll see it in the back of the fridge where the water line goes in)is leaking this water freezes up inside the filling tube for the ice maker and when it calls for water it can't go through.Or could be this valve doesn't work, in both cases it needs to be replaced.
Aug 09, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water leak in ice maker tube
Hi, Make sure the inlet tube has no restrictions. Sometimes ice will start to form inside the inlet tube and cause pressure so the hose leaks. If this does not help. you might need to change the change the inlet tube
Please let me know if I can assist you further.
Vic
Jun 20, 2009 | Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
My amana sise by side fridge wont drop the ice
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Jul 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana ACD2232HR Side by Side Refrigerator Logo
1,182 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
