Question about Arctic Air GDR22CW Refrigerator Commercial
Arctic Air fridge stops each night and needs to be reset
It starts up again fine after it is reset. But even on its own circuit it shuts down every night.
    Sergeant:
    Champion:
  • 214 Answers
Please check your input voltage at night it must be between 210v - 240v if it is all right than please change your timer which was located in your back of your refrigerator. i'm sure that it your problem will be solved.........
Posted on May 14, 2009
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
Our tenant says she heard the fridge beeping late last night. This morning, the fridge is completely shut down. The electrical outlet that it's plugged into has power, but the fridge isn't working. Is...
Do the lights light up in the fridge or freezer? If so then your power will be fine. If you look into the fridge do you have a board that sit up the top front with the temperature for the fridge a freezer on it? It will either be that board (most common) or the start relay which connects onto the compressor in the rear of the appliance, they can sometimes burn out and stop the compreeeor starting and the appliance will lose the temperature and the noise you hear is the alarm warning you that your food is at risk.
Nov 04, 2010 | Maytag MSD2756GES Side by Side...
I have a arctic air fridge thats freezing cold
the thermostat is bad and must be replaced..easy fix don't worry.A repairman can do this for little money
Sep 16, 2009 | Refrigerators
Correct light bulb for Arctic Air Fridge (R22WW). The
Socket,light/lamp,25 w You can get it at an appliance parts store or even wall-mart.
Jul 01, 2009 | Arctic Air R22CW Refrigerator
2 weeks ago one of my units stopped working properly. It got warm during the night even though I heard the unit running. I shut it off and called for repair service. They changed the thermostat and it...
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Leaking fridge
The U shaped copper tube is most likely the drain tube where the water frost defrost exits and drains into a drain pan to be evaporated. Even thing is fine, do not shut it down nor call for service. If you hear it again wait twenty minutes and it should stop. Then check it and I'm sure you will find it is O.K.
Have a nice day.
Sep 16, 2008 | Refrigerators
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Arctic Air GDR22CW Refrigerator Commercial Logo
123 people viewed this question
Top Arctic Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
richie46
Are you an Arctic Air Refrigerator Expert? Answer questions, earn points and help others
