Question about HP Pavilion a630n (PC109A#ABA) PC Desktop
No audio device for hp a630n
My computers sound is gone device manager says no audio device and it sayd i have no sound card, it makes beeps here and there but thats it. please help. i have legacy audio drivers and i cant find them on the net.
  • 7 more comments
  • yajaira782 May 13, 2009
    thanks for trying the realtek download didnt help it said it couldnt find a match on file. thanks any other ideas?
    There are no devices listed.
  • yajaira782 May 14, 2009
    i will let you know if this helps thanks!!
  • yajaira782 May 15, 2009
    I enabled and disabled audio in bios so is there nothing else i can do?
    Well the first thing I saw was that it was on "auto" so I then changed it to enabled and pressed f10 to save and exit. Did I do it wrong? It said to press f10 to save and exit so I did and it went straight into windows startup. Thanks for all your help! Its still not working though. I
  • yajaira782 May 16, 2009
    Thanks so much!
    Where can I buy one?
    Thanks!!
  • yajaira782 May 17, 2009
    I am going to have my fiance check for me. My USB port just sunk into the tower so that is also broken and on the same day as the sound going off my printer broke. It just wont turn on anymore! So we may need a new pc soon. None of my 3 USB ports work anymore now.
    Sergeant:
  • 219 Answers
Please visit this web-page:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=426322
You're looking to download the first driver on the list, the, "Realtek High Definition Audio Driver Update." Once you download it simply opening the downloaded file should install the driver for your sound chipset. If not, read the instructions on the download page for detailed step-by-step instructions on how to properly unpackage and install the drivers.
If installing these driver's doesn't do the trick, let me know. I'll try to help you debug the problem and get the whole issue resolved.
Let me know how it turns out or if I can assist you further.
Posted on May 13, 2009
  • 5 more comments
  • Peter Steiert
    Peter Steiert May 13, 2009
    Well then, does the device manager list any devices with a question mark icon (?) next to them?
    It sounds as if your sound card/chipset isn't being recognized and is therefore presenting this problem.
  • Peter Steiert
    Peter Steiert May 14, 2009
    Okay, on system startup enter the BIOS. To enter the BIOS, watch the screen while the system is starting up. In particular, we're looking at the screen before the Windows logo (Windows XP, Vista, or even 7 loading screen) loading screen.We're looking for some text which allows us to enter the BIOS setup. It will look similar to this:
    Press to enter Setup.
    The moment you see that text, press the button associated with the text (in this case F2) repeatedly until a new screen appears which will be the BIOS setup screen. Your text may be different though, so keep your eyes open and don't expect to be pressing F2.
    Once inside the BIOS, browse around the menus. We're looking for an option which will enable or disable onboard sound. Once found, make sure it is set to, "Enable" or something of similarity. If it already was, disable the device then exit the BIOS saving changes. If the problem persists upon the next startup, enter the BIOS again enabling the device you just disabled. And if that doesn't do the trick, it sounds as if your sound chipset has gone bad.
    If your sound chipset has gone bad it won't be worth replacing. Simply buy yourself a PCI sound card which will work with your system. The upside is that now your processor won't have to play the sounds allowing it to do more important things (speeds up your computer some).
    Please note, the above suggestion is if you are/were using onboard sound. If you're not using onboard sound and instead are using an actual sound card, let me know.
    Let me know how it turns out. I really hope this will solve your problem.
  • Peter Steiert
    Peter Steiert May 15, 2009
    Wait, did you enable the onboard sound in the BIOS, then exit the BIOS
    saving changes. Or did you enable afterward immediately disabling the
    onboard sound in the BIOS then exiting saving changes?
    We want to leave the onboard sound enabled after we exit the BIOS saving changes.
  • Peter Steiert
    Peter Steiert May 16, 2009
    Yes, that is correct. So it appears that the soundchip is dead or broken in some way.
    The easiest way to get around this problem (practically fixing it) is to buy a new sound-card. Let me know if you need assistance locating a sound-card that will work with your system. I will be more than happy to assist you.
  • Peter Steiert
    You don't necessarily have to buy one from this website (although it would make sense since they are at a very low price). It's mainly to locate a sound card you think will meet your needs.
    NewEgg
    Once the page loads navigate to Computer Hardware>Input Devices. Afterward click, "Sound Cards" located in the menu on the left (Make sure you don't click, "Sound Card Accessories." It's not the same thing).
    You will want to buy an internal sound card, not a USB, Firewire, or some other form of external sound card. Typically internal sound cards are seated in the PCI or PCIe (x1) slots. If you need help figuring out if you have an open PCI or even PCIe (x1) slot, let me know. I will gladly assist you in opening up your computer to locate just such a slot.
    Please note, you must be certain that you are buying a sound-card that fits and works with your computer. As mentioned above, you must first know if you have the slot (PCI or PCIe) to support the sound card. Then secondly you must ensure that the sound card works with your operating system (Windows 2000, XP, Vista, 7, Mac, Linux, etc...). Once you have confirmed both you can continue with searching for more sound cards or buying your selected sound card.
    Once again, if you need me to explain anything mentioned above, or if you simply require assistance on a different matter, let me know. I'll be more than happy to assist you.
  • Peter Steiert
    Peter Steiert May 17, 2009
    I suppose that means you don't need information on how to determine if you have an open PCI or PCIe (x1) slot? :-)
  • Peter Steiert
    Peter Steiert May 18, 2009
    Wow, that's horrible!
    Check with HP, it might still be under warranty. If it is you can get it fixed or even replaced, for free.
Sound has gone bad
Which operating system ?
XP If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer W7 click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps.
Dec 20, 2012 | HP Pavilion BV704AA p7-1020 Desktop PC -...
We have default buildin sound card on HP brand PC. i setup windows recently, from then sound device not work. show now sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 24, 2011 | HP (400745-001) Sound Card
The SD card reader built in to the front of my HP Pavilion a630n Desktop is not recognizing that there is a card in the port at all whatsoever. i know for a fact it's not the card so perhaps there is a...
Check the driver, see if it is working probraly, and may need to be reinstall or update... also check to see if your sd card would work on another machine. If it does, then it is not your card...sometimes windows won't reconize it until it's formated, but then in this case, it should reconize it, but you wouldn't be able to open it only. So i'm sure it's your driver, or the media card device is damaged. See if you notebook reconize the hardware in device manager
Jan 27, 2011 | HP Pavilion a630n Notebook
Sound card issue hp laptop
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 21, 2011 | HP (400745-001) Sound Card
No sound device driver in my window xp
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 22, 2010 | HP Sound Card
My Toshiba Satellite A135-S2386 laptop all of a sudden says "no audio output device is installed" any help on how to fix this would be appreciated! I have gone to device manager, however states there is...
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 13, 2010 | Toshiba (4CH-VOUT) Sound Card
No sound on my computer
good luck
Sep 04, 2010 | HP Computers & Internet
Don"t hear anything at all.
control panel sounds and audio devices,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow? right click re-install drivers
good luck
Aug 29, 2010 | HP (153147-001) Sound Card
I lost the sound on my computer
click on start then RIGHT click on my computer(xp) or computer (vista/7) then click on manage then click on device manager on the top of left of the computer management screen.
On the top right window will appear a list of all devices on your computer. Check that the sound card has no yellow exclamations marks on it and that it is functioning correctly. If you see a error with it then simply right click on it and click uninstall or remove. Restart the pc and see if it works if it still isnt functioning correctly you should go to hp and download the audio drivers for your pc
they can be found here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3239117&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
let me know if this helps
Dec 29, 2009 | HP Pavilion a1610n PC Desktop
Laptop will beep but has no other sound.
To check, click windows start button, point to computer, click manage, then look for device manager. If you see an exclamation or "x" mark on your audio device this means that your audio driver is not properly installed.
Uninstalle the audio driver then re-intall it again. visit www.hp.com/support and look for your audio driver if you dont have the cd installer.
Jun 01, 2009 | HP Compaq Presario V5305WM Notebook
HP Pavilion a630n (PC109A#ABA) PC Desktop Logo
828 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
