Question about Dell Office Equipment & Supplies
Paper immovable in final discharge roller; cannot budge; efforts to do so only rip it!
Patiently pulled paper out a little bit at a time.
Posted on May 15, 2009
Paper gets folded and jams as the paper gets pulled into the machine from the paper tray below in my image class MFN
clean the roller's with some rubbing alcohol and the paper should go straight, UNless something got stuck in there, Ripped piece of paper might also be the cause, the older the unit the more it needs the rollers cleaned,
Jun 05, 2014 | Canon imageCLASS MF6530 Monochrome Laser...
Cannon pixma mx922 paper jam
I had a very bad jam (paper tore...you know the drill...see upper panel). My wife and I used a chopstick and hemostats to gently, gently lift the rollers and ease the paper out (lower panel...most of the paper has been pulled out). The stick should be applied to the support between the rollers. You have to go from roller-pair to roller-pair, easing the paper out without ripping it.
Oct 14, 2013 | Canon Office Equipment & Supplies
I have a paper jam. Some of the paper is still stuck in the rollers. Machine said to open back door. I did and can see the pieces of paper but when I try to pull them out with a pair of needle nose...
HI, Try to roll gently and slowly the paper roller and pull the piece of paper in the same time. Grab the piece of paper close to the roller to prevent tearing. Good luck!
Mar 03, 2011 | Dell 5210n Laser Printer
Paper is pulled sideways infrom feeder....
Look for possible dirt or sticky material in the roller. use some methy spirit to clean the rollers that take up the paper.
Check if there is any paper stuck on to the rollers, if so remove and clean.
Check if there is any wearing of the rollers, alignment of the rollers.
Finally use printer paper as thin paper might be chewed in.
Hope you check with my advice.
Aug 21, 2010 | Canon PIXMA MX310 All-In-One Printer
Really bad paper jam
On the back of the printer is a access cover. You should be able to remove the jam from there quite easilly.
Aug 04, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Toshiba 3560 paper feed jam at first roller; paper stops.
hi,clean the first roller & check little piece of paper around first roller.finally replace first roller.
May 17, 2009 | Office Equipment & Supplies
Paper roller
Use an Xacto knife and carefully cut away the paper and remove it with a pair of tweezers.
Jul 15, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
EPSON STYLUS PHOTO R 200
THE ROLLERS THAT PULL THE PAPER THROUGH SEEMS TO BE MESSED UP. WE HAVE TO REPEATEDLY RE-ADJUST THE PAPER, THE RED LIGHT FLASHES, OVER AND OVER AGAIN BEFORE IT FINALLY PULLS THE PAPER IN TO PRINT. ARE THE ROLLERS SHOT? DO WE NEED A NEW PRINTER?
Jun 30, 2008 | Epson Stylus Photo R200 InkJet Printer
Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Jun 13, 2008 | Fellowes PS70-2CD Shredder
19 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
