Question about Toshiba 32A41 32" TV
Television cutting out
I have a toshiba television and recently it keeps cutting out and even when reset on timer it cuts out how can i prevent this from happening it has not happened before and now it cuts out every five minutes.
  • Droja May 24, 2008
    Television cuts out. When hit on the side it comes back on
  • Toshiba Master
  • 5,568 Answers
These two problems may not be related; the first is either a reaction of an overvoltage protection circuit that monitors the ~ 25kv supplied to the CRT or the sign of a decaying component, most likely an electroytic capacitor.
Sometimes, this component can be seen to be failing by a bulge on the top (or end, if horizontal) of the package or the appearance of a crusty desposit around the seal.
The second problem is probably coming from a failed or fractured solder joint, often called a 'cold' solder joint.
These quite often respond to mechanical jarring or disturbance of the board on which it occurs.
Looking for these without signal tracing capabilities can be a lifetime task.
Labor charges in both cases (if you still have a shop around) could be a significant amount.
Posted on Jun 26, 2008
I have a Mitsubishi 60inch 60737 replaced the bulb last month.now it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
May 27, 2015 | Mitsubishi Televison & Video
Mitsubshi television cant set timer wont come on
Does it stay on briefly and have a solid blue screen and then shuts off?
Mar 16, 2012 | Televison & Video
The tv keeps cutting off. I have checked to make sure that the sleep and timer is oof but the tv still keeps cutting off. it cuts off sometimes every 5 min, and sometimes every hour or two.
Hi William,
If you have necessary tools and test instruments, and know safety precaution in basic troubleshooting, I would advice you to check/replace the electrolytic capacitor in the power supply section, this cap malfunction and produce out-of-regulation which sense by the feedback circuitry and turn the unit into subsequent shutdown. Also, look for a bad solder joints on the board., it will do the same thing. Secondary reasons of symptom is Voltage Regulator IC, and microcontroller circuitry.
If you can't do the job yourself, I would advice you to look for a technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 17, 2011 | Toshiba 27AF45 27" TV
My 62 inch Toshiba DLP keeps getting the timer rec error. I even bought a brand new bulb for it, what can it be?
have you reset the lamp timer I think that is all you need to do
here is the link
http://www.ehow.co.uk/how_7259862_reset-toshiba-dlp-lamp-meters.html
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE!!!
Oct 18, 2010 | Toshiba 62HM95 62" DLP HDTV
Why do my tv keep cutting off by itself?
check your tv if the timer is on..if the timer is on,off it..
Jul 28, 2008 | Symphonic ST420FF 20" TV
MAGNAVOX TV /DVD,VCR CUTS OFF
is the VCR trying to eject a tape even if there is no tape in machine. then shutting down ? if so the vcr sensors need to
be replaced
sensors avalible from funai
Jan 03, 2008 | GE 13TVR72 13 in. Combo
Toshiba TV picture has shifted high
if it cannot be adjusted then there is a problem in tv. your problem is in vertical output circuit Can this be corrected easily ? yes or do I need to start looking for a new TV? I love this one and would like to keep it a while longer. not to look for new tv.you will keep it for longer that has a picture that recently shifted upward and now cuts off about 1 inch of the top of the picture. Otherwise it functions properly. your problem is in vertical output circuit please check 1loose contact in vertical output section 2 capacitor defective in v/output. it is a common problem. it is a not a major problem. if you are not tech person get it done by skilled tech. hope this will help.
Sep 30, 2007 | Toshiba 32A33 32" TV
Toshiba 32A41 32" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
