Question about Necchi 3537 Mechanical Sewing Machine
Needle not going up and down on necchi 544
I have just been given this machine, and everything is working (light and motor)  except that the needle will not go up and down. I don't have a manual for it, but wondered if anyone else has had this problem. Thank you.
  • 34 Answers
There should be a button in the balance wheel on the left side of the machine. Not sure on your model, but most of the Necchi's pull out and push in. That disenguages the needle arm to wind a bobbin. Some of them screw in or out, but generally pull out. You might try pulling it out and then pushing it back in, until it clicks. Then it should work fine.
Posted on Jun 08, 2009
Necchi Lydia 3 type 544 motor slows down
Clean and oil all mechanical parts, if you have a belt, check it too, maybe it's slipping. If everything is OK. you could have a bad foot switch, or motor
Mar 17, 2013 | Sewing Machines
My Necchi 537fa is sewing sluggish. Motor spins but needle moves slow. What do I do to fix this?
If your Necchi has an external motor, take the belt off and run it.... is the motor sluggish? If so... that's where you start. motors need to be oiled, typically with oil and grease ports on either end of the motor housing.
If the motor spins up nicely,... you need to clean and oil the rest of the machine. Start underneath if the bottom workings are exposed, oil all the places where metal joins metal. Then do the bobbin and feed dog area... then look along the top and sides for oil parts.. give them a drop or two...Finally, see if you can get into the head where the take up lever and such are... oil the needle bar, presser foot bar, etc.
It's a dirty job... so prepare a good space for your machine. Liquid Wrench will help you free up gunked up and rusty parts. Fine grade steel wool (0000) and Cotton swabs help.
Good luck
Oct 10, 2012 | Necchi 3537 Mechanical Sewing Machine
Machine binding
Have you been lubricating the machine in accordance with the manufacturer's recommendations? Sometimes a drop of "3 in 1" (or equal) light machine oil in the right place can work miracles.
Jan 19, 2012 | Necchi Sewing Machines
I have an older Necchi 544. It will pick up the stitches when I do it manually, but skips when I try to use the foot control. HELP
Could the needle be in backwards?
Flat shank to the back. Is the needle fully up into the housing?
If these check out okay then the timing could be off. If it hasn't been serviced in last 2years then it might be time for one.
Apr 15, 2011 | Necchi 3102 Mechanical Sewing Machine
Necchi 3537 Mechanical Sewing Machine Logo
272 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
