Question about Beverage-Air MT27 Beverage Cooler Commercial
Just bought a small Beverage Air cooler with glass door, appears to be an older wine or beer cooler, in a garage sale with lose electrical wires. Appears to be a AZ or BK series.Need schematic to attach wires correctly. HELP!!
    Problem Solver:
  • 8 Answers
Maybe a indicator of greater problems having been left that way.
Posted on Dec 12, 2013
SOURCE:
SolutionGuy
  • 331 Answers
SOURCE: bev air cooler
Bill, the main reason I've noticed for higher than normal temps in these boxes is filthy condenser coils (this will affect pressures in your sealed system). Remove the front lower panel and inspect your coils. Use a coil brush or a dust broom to thoroughly clean them up, don't use water. You can also pick up some condenser coil cleaner in a spray can from your local appliance parts store, but it's not necessary (the fumes are strong and may be objectionable to your customers... it gets 'em really clean, though!) After cleaning the coils, allow 24 hours for temps to stabilize. If they don't, here is a site for Beverage-Air, contact your local servicer with you exact model and serial number for pressure specifications. http://www.beverage-air.com/technical.service.html Hope this helps! Let us know, will ya?
Posted on Aug 13, 2007
  • 4 Answers
SOURCE: I have an older beer cooler. the fan costantly
You would need to be a certified refrigeration technician to even buy R-12, since it is a CRC refrigerant. The kegerator probably doesn't have service ports so you would either have to braze a low-side port in or use a piercing valve, and fix wherever the refrigerant leaked out from. Basically, by the time you pay a refrigeration tech to do all this, it isn't worth it and you would be better off buying a new one
Posted on Jul 26, 2009
  • 1300 Answers
SOURCE: need to see if evap fans r working
http://www.beverage-air.com/uploadedFiles/docs/CFG_CRG_KF_Series809-046A.pdf
this site has your manual and the manual has wiring diagram.
also has some common trouble shooting questions and answers.
Posted on Jul 11, 2010
  • 1300 Answers
SOURCE: my BM23 beverage air kegerator runs constantly and
I would definately start there. That is what contols the cycling of the compressor.
Posted on Jan 30, 2011
  • 4 Answers
SOURCE: What does the overload relay look like a
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Posted on Nov 18, 2011
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
I need the Haier 18 bottle wine cooler instruction manual.
Hi There,
I was able to find two 18 bottle wine coolers on the Haier site.
The first is model number HVTM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtm18dabb
The second is model number HVTSM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtsm18dabb
On either product page the manual can be downloaded from the "product support & downloads" tab
Have a great day!
Jul 18, 2012 | Refrigerators
If the dial is labled 0-9 what nimber is the coldest?
0 is warmwst,9 is the coldest.set it at +2C so that wine/beer dont freeze.beer is best served at 2c.
Dec 31, 2010 | True TBB-2 Beverage Cooler
I LOST MY KEYS FOR THE COOLER WHERE CAN I BUY,OR HOW DO I OPEN THE DOOR
you will like this,same thing happened to someone i know and they went into thier local dealer and asked to borrow a key,the dealer said yes but will take a $25 deposit for the return within 48hours.
guess what.....the first key did not fit,but the third one did.....happy ending......i supose they could have taken the cooler to the dealer,but is was full of beer......
Aug 14, 2010 | Haier HC125FVS Wine Cooler Beverage Cooler
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
2.5 cub. ft. beverage cooler never has chilled cold enough for me. DBC259BLP. I operate on max cold. Has been like this since I got. I was in home remodel mess when I bought this, had no time to contact...
if its a thermo electric model (just has a fan) this is normal, it would take days to get beer really cold, and not opening the door. little fridges are gutless, this is normal
Jul 24, 2009 | Kitchen Appliances - Others
I have an older beer cooler. the fan costantly runs but the refrigeration part of the beer cooler doesn't keep the keg cold? ? ? It's refrigerate is r12 cooled. Do you think I could just re charge the...
Jun 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air MT27 Beverage Cooler Commercial Logo
209 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Marvin
Marvin
Joe Palazola
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
