Question about AOpen AX45-V (91.88I10.004) Motherboard
Help pc problems???
Hi there:
I have a AX45-v aopen motherboard, p4 chip, ATX-250gu power supply, win XP with 1GB RAM. The problem is my pc won't power up all the time.  1st attempt at powering up, the HDD light and cpu fan turn on, the second attempt, the power light, hdd light and cpu fan turn on, I have to unplug the pc, leave it for 15-30 mins and plug it back it and it will boot up.  I have checked my hard drive for errors viruses etc. NONE. I have replace the motherboard, as I was told my a tech that it was the problem but the pc is still behaving this way. I checked all the cards, ram, and componets and everything is tight.
What could be the problem?
Thank you!
Karen
  • 9 Answers
CHANGE THE POWER SUPPLAY.. BUT FIRTH..
1-UNPLUG HD AND TEST WITH FLOPPY OR CD BOOT DISK
2-UNPLUG YOUR MEDIA ROOM LIKE CD OR DVD AND TEST ONLY WITH FLOPPY BOOT DISK
3-UNPLUG VIDEO CARD AND ALL CARD ON YOUR MOTHERBOARD.. TEST ONLY WITH THE FLOPPY DISK AND ONBOARD VGA.. OR GOOD TESTED VGA CARD.
EXCUSE MY BAD ENGLISH.
CO3OV
CUBA
VICTORES45@YAHOO.ES
Posted on Oct 15, 2007
Do you know what the max memory supported on the AOpen AX45-4D motherboard? Thanks!
From what I can remember the motherboard supports 2GB of ram (1x1GB in each slot).
Regards.
Jan 07, 2011 | AOpen AX45-4D Max Motherboard
I have an ax45-v that wont boot past ram check..ram check says ok but than comp freezes
Change ram bank, clean your ram, try to load windows by pressing F8 key and then in Safe Mode.
Regards;
Hassan
Jul 15, 2009 | AOpen AX45-V (91.88I10.004) Motherboard
Win XP re-starts after Turn Off computer.
hi im josh! may i help you? i had the same problem of yours before but it was already resolved.i found out that the power led connection was mislocated. you can found this inside the pc.on the motherboard connection to power button.two small wires there try to check. hope i helped you.good luck.
Feb 19, 2009 | Computers & Internet
No Power On Start
Problem Solved, changed the power supply with a 450watt one and it booted fine .
Jan 30, 2009 | PC Chips P25G Motherboard
Ram upgrade
well u r a women so ax45v has to be thrown away
May 15, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
Installing a new power supply
Those are the cables that connect to the motherboard from the power switch, to the power LED and the hard drive activity LED.
Try following the diagram on the following page to know where to put them in:
http://www.fixya.com/support/p365479-aopen_ax45_v_91_88i10_004_motherboard/manual-16477/page-29
Dec 24, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Hard drive shuts off?? I think.
replace your power supply, you need to upgrade this to at least 500watts to avoid problem like this, there is no problem with your hard drive its your power supply
Dec 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
My pc problems
Maybe something is wrong with your power supply. If power supply get old, it will restart the computer by itself. Try to borrow a friend's power supply and test it out.
Nov 09, 2007 | PC Chips P23G Motherboard
Motherboard problem
if you have tried resetting the bios by putting the jumper across pins 2-3, then back to pins 1-2 and it still wont boot into the bios and you know the memory is ok, then the bios chip on the motherboard is damaged and may not be easy to replace as the board is quite old.
Aug 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
AOpen AX45-V (91.88I10.004) Motherboard Logo
59 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
