Question about Dell Inspiron 630M Notebook
630 m notebook problem
Every time I connect the ac to the laptop, the LED on the power charger blinks once then nothing happens after that. My laptop looks "dead". Nothing appears on the screen. Please help. Thank You.
    President:
  • 317 Answers
Sounds like you have a bad jack inside your laptop.  These need to be replaced by a professional, because it requires opening your laptop and soldering a new jack onto the board.
Posted on Oct 14, 2007
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
HP 4530s will not power up no matter if the power source is plugged in or with battery. When I push the power button there is nothing happening. I noticed that just above where the power plug in to the...
Try another cord/charger with the EXACT same power specs. Has the cord been pulled while it was plugged into the laptop damaging the AC jack? If you have a multimeter you can verify you are getting the correct DC volts at the laptop ac jack plug. Try HP Support for a explanation of the small led blinking: http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?locale=en_us&taskId=135&prodSeriesId=5060880&prodTypeId=321957
Apr 07, 2013 | HP Computers & Internet
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Ok i got a hp g60 and its weird cause the battery aint charging .. now wat techiesguru was a great success on getting it to come back on.. how ever i had to also unplug the internal battery as well and do...
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 04, 2010 | HP G60-230US Notebook
Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
My laptop toshiba won't power up. When I connect my charger to the laptop the charger blinks continuously...then turns off. But the laptop won't work at all. The power led on the laptop doesn't even lights...
The charger is defective take it to a store that sells them and ask them to plug in a charger for it wait for 20 minutes and if it works to kow the charger is bad, if it does the same thing then you know the bateery pacl is bad.
Jan 11, 2010 | Acer Aspire 5610-4648 Notebook
My led in the adapter blinks
Its probably Ac adapter fault try different good known adapter if the issue will be the same then its fault of Mother board power circuit.
Jan 01, 2010 | Dell Latitude C640 Notebook
Hi! When I press power button, the front LED battery blinking for 5-6 times, then no longer happen. If I remove the battery pack, no one LED blink, no one LED light, nothing happens. The output voltage of...
Your battery pack is not charging. By removing the battery pack and trying to run on AC only you have proved the AC adapter is either not working or the power is not getting through to the laptop.
The best way to sort this is to try another adapter and see if the laptop works, if it does then your adapter is broken (this is possible even though it reads 19.1 under no load.)
If the laptop still does not work with another adapter then the laptop itself will heed repair.
Oct 31, 2009 | Acer Aspire 1640Z Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 630M Notebook Logo
46 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
