No response to DEVICE OR AUDIO/VIDEO buttons
I have a 65 inch hdtv projection model# ws65615. The tv works fine using any of the buttons on the remote or tv control buttons. Until I hit the DEVICE OR AUDIO/VIDEO buttons on the remote or the tv control buttons. Once I hit those buttons there is no response and after about thirty seconds the tv shuts off and the green power button starts blinking. I have to hit the reset button in order to turn it back on. In other words the tv is fine as long as I dont hit the DEVICE OR AUDIO/VIDEO buttons. All the other buttons are fine. So I can't watch any devices on my tv because it will not respond to DEVICE OR AUDIO/VIDEO buttons. Can anyone help? Thanks, Wayne
2 Suggested Answers
SOURCE: I have a 65 inch hdtv projection tv model# ws65615
Need actual Mfg. so I can have Comcast program the Remote??? Comcast has NO listing for the program numbers for Vivitek.
Posted on May 13, 2009
Video on 65 inch Mitsubishi Tv model WD-65638 is not working how may i reset this or even fix the situation.
If you have the original working Mitsubishi remote you can try a soft restart:
Menu, 1,2,3, enter
SD TECH
Aug 31, 2011 | Mitsubishi WD-65638 65" DLP HDTV
65 inch tv turned on and volumn went all the way high remote does not work also can't change devices
Make sure the button either on the remote is not depressed all the time or on the front of the television!! This will be the main reason that the volume is going to MAX all the time. Usually if you press any button on the tv or remote and hold it down such as you mentioned, it will lockup the microprocessor to that function specificly and it won't take anyother instructions until you unstick the button or get it to stop going all the way UP!
Try that and let me know if i solved your problem.. God luck from the TV GURU
Jun 09, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
No sound
A DVI cable does not have an audio connection, along with the DVI you still have to run an audio line from the device (DVD player, cable box, satellite receiver) to the TV. HDMI contains both audio and video.
Sep 30, 2008 | Hitachi 57F500 57" Rear Projection...
Mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
Sep 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
When there?s any bright white light, the unit just loses the signal .
Good Day, littlejhon4u;
Try this and/or try using different input: White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change. Good Luck, big IRISH. PS; Adjust this ONLY.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Video issue
unplug connector ZF behind the speaker grill if this restores normal operation than you have bad buttons on the front of the tv.
Feb 26, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
My sony 65 inch projection does not work
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 26, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
