Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
Green LED light flashing and can't shut it off??
I was trying to set up my new blackberry 8220 and somehow I turned on the LED flashing light (green) and I can't seem to get it to stop!
PLEASE HELP!
  • marnid May 13, 2009
    Thank you! That did work, but I also found out how to do it right!
    Go to OPTIONS...then Screen/Keyboard...and about half way down you'll see: LED Coverage Indicator..On/Off...turn to OFF!
    Welcome! Glad to help ~ :o)
    Problem Solver:
  • 6 Answers
I had the same thing happen to me during the 1st wk when I had my phone. Not sure how it happened, but all I did was shut my phone off and removed the battery. I waited about a minute before reinserting the battery and turning the phone back on. It took about another minute for the phone to initialize itself. After that, problem was solved.
Good Luck ~ :)
Posted on May 13, 2009
  • pdme
    pdme May 13, 2009
    Thanks for the info! I will definitely put that in my arsenal of BB How-Tos ~ :)
Mitsubishi WD-48511 Flashing green power light
The green light should only blink if set has been unplugged---upon plugging it back it will blink for about 70 seconds and go out----this is the set booting up and is normal.
At that point you should be able to turn the set on-----what happens when you try?
Mar 17, 2012 | Mitsubishi WD Televison & Video
How to remove the green light on at 8220 blackberry mobile phone
If your talking about the led on the top. You can't. It's a multi-colored mico LED that's attached to the board, and trying to get rid of it could damage the board completely and render your phone useless
Sep 10, 2011 | RIM BlackBerry Pearl 8100
Hi, I have new BB9700 and when I put it on charge first time there was red light on constantly and green light flashing after a little while green light is also on constantly why is that
Within the menu of the BlackBerry, one can set up the red, green and indeed blue led to do various functions, for instance, my BlackBerry used to have a green led on permanently to show that it was receiving data from the transmitters.
Select what function you require it to do. When you have sussed out how to adjust it, you may find it a usefull function.
Oct 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Alerts Sounds Just Stopped On My Blackberry 8220
go to profiles. and click advanced options and change it there it will have an option for everytime your phone should ring.. turn the Led light off as a reminder
Jul 02, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Green light flashing on blackberry pearl
This just means that the phone has coverage. under options and then screen/keyboard, you cna turn it off by where it says LED coverage indicator.
Apr 10, 2009 | RIM BlackBerry Pearl 8100
8310 blackberry curve
To answer your first question, the green flashing light is the coverage indicator. It will flash green when you have a wireless signal. If you want to disable that then go to Options > Screen/Keyboard and then set the LED Coverage Indicator option to Off.
Sep 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
How to switch off the green and red LED ?
My wife and I both have Pearl's. I found that the problem on both of them was caused by Color Pearl, an application that allows you to change the color of the Pearl's trackball. It was not a problem until upgrading the Blackberry software to v 4.5. I tried rebooting, removing the battery, etc. The light always came back on after an alert. Removing the application ColorPearl did the trick. Just go to Options>Advanced Options>Applications and delete ColorPearl. Hope this helps someone.
Aug 31, 2008 | RIM BlackBerry Pearl 8100
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
477 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
