Question about Janome 6019QC Mechanical Sewing Machine
Frabic won,t feed
Seems to be threaded fine bobbins correct but there is no forward motion when sewing needle just going up and down
  • 3 Answers
Have you checked that the feed dogs are raised? mine has a switch at the back -
Posted on May 20, 2009
How do I get the sewing needle to move forward on my Janome sewing machine?
Check to see if the feed dogs are lowered. There should be a lever or switch on the front or back of the sewing arm that drops the feed dogs for free motion sewing.
Also check under the needle plate for lint build up. This can prevent the feed dogs from raising.
Feb 25, 2015 | Janome Sewing Machines
JUKI BOBBIN THREAD WILL NOT FEED
Most machines require that the bobbin in the case unspool in a certain direction its considered common knowledge I guess because it doesn't seem to be written in the text of manuals... but is indicated in the photos. make sure it's unspooling correctly.
Secondly. Please make sure you have the correct needle for your machine. Some machines do not use a 15x1 (most common needle) Let me show you. (see photo below) Clearly the 241x1 won't fit into your machine. BUT the 15x1 will go into the machine that requires the 20x1.... and the result is it won't pick up the bobbin thread.
Start there. Then check your timing.
Sep 05, 2012 | Sewing Machines
I have a singer inspiration4212 and I was sewing and a piece of materialwent down into the feed dogs and I had to tug a bit to get it out.Now my bobbin won't pick up the thread. I have taken the bobbin...
even if the needle is not bent, the needle could have a burr on the tip, I would try a new needle
clean under the needle plate & in the bobbin area for loose thread or lint
if the machine still does not work then it could be out of time
Aug 02, 2011 | Sewing Machines
The first few stitches are just fine but then the machine seems to seize up and stops. When I try to remove the fabric I can barely lift it and then I must cut through a veritable bird's nest of threads on...
You may have a jam under the needle plate. Take it off and have a look.
It is often a simple case of one of the threads not passing through the tension discs correctly. Try re-threading upper and lower, making sure the presser foot is up at the time.
Are you sewing a fine material? Sometimes fine fabric gets pushed down through the universal needle plate hole which is slightly elongated. If this is the case you need a straight stitch needle plate. You cannot do zig zig or anything other than straight stitch with this plate.
If re-threading does not do it and you do have a soft fabric, try popping some freezer paper or similar under the first few centimeters of sewing before buying another needle plate, it might work.
Jan 25, 2011 | PfaFF Sewing Machines
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
Missed stitches noise when it happens
Firstly, turn machine off then turn back on. Change needle. Re-thread the top and bobbin threads. Make sure you have not set the machine for a sideways stitch but you have been using a single stitch foot (recipe for Disaster!). BEFORE trying to sew, wind the machine by hand through a stitch or two (take the thread out of the needle's eye first) and look closely to see if the needle is in fact hitting something. If it is, then the needle needs re-centering and you will have to take the machine for repair to get this done.
Make sure the top thread is going into the tension disks. The presser foot MUST be up while you are threading. Hold onto the thread just as it comes off the spool and when you get down to the needle give a tug to be sure the thread is seated in the tensions before threading the needle. When you insert the bobbin, be sure the thread "clicks" into the tension slot on the bobbin case. Check the Sewing Advisor to be sure you are set for the correct fabric and stitch for what you are sewing. Have you cleaned out the bobbin area? Remove the clear or smoke bobbin cover, either use the tool provided or just press down firmly and slide forwards the metal feed dog cover (feed dogs down first), lift out the light grey plastic bit that half covers the bobbin case, remove bobbin case. Use the brush and clean out all the fluff from the bobbin area. Then check the bobbin case and clean it too. You can use a piece of strong thread or UNWAXED dental floss to clean out between the tension springs (the bit where the bobbin thread 'clicks' into). Reassemble the bobbin pieces in reverse order, making sure that when you replace the metal feed dog cover you push it all the way to the back and it too will 'click' into place. Hope something in the above works for you.
Dec 23, 2009 | Husqvarna Designer I
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
Free Motion Sewing - Jams
The Designer 1 usually has a very nice free motion stitch using the V1 stitch. It should pull only slightly to the rear so that no bobbin thread shows while doing free motion embroidery. Upper tension may be increased for balanced stitch when stippling.
If your machine doesn't sew with the regular stitches with the teeth up, and it's properly threaded, the thread must be dragging on the bobbin case somewhere. First get the machine sewing a straight line, then try V1 again.
Feb 19, 2008 | Husqvarna Designer I
Janome 6019QC Mechanical Sewing Machine Logo
168 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
