Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Prima lpr 600 dishwahser
Hi when i press the start button and close the door sounds like the pump starts but 20 seconds later it bleeps open the door and the start ligh is flashing any ideas
martin heath
mail me at tobs127@yahoo.co.uk
thanks
it says prima lpr 600 on the door
  • 3 more comments
  • mollymouse Jul 21, 2008
    put dishwasher on it sounds like its starting to work then it stops and starts beeping the light on the top of the door flashes 7 times can anyone suggest a cure
  • stratman2 Oct 29, 2008
    I have the same problem. The machine bleeps continuously and the start light is on. Saw the post about press the dry heat button for 4 seconds but which button is that. I've tried pressing everything in sight but it still does it.
  • Anonymous Nov 12, 2008
    Start light flashing continously and regularly (no pauses). Tried pressing all buttons in different combinations but to no avail. Shut door motor starts and then beeping sound until you open the door, the start light flashes continuously.
  • dlan1 Mar 04, 2009
    I hve held a button down that beeps after 4 seconds but it still continues with the same problem, any other suggestions please?
  • Metasse Apr 09, 2009
    Same problem
    Problem Solver:
  • 6 Answers
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more.  I'd suggest trying this on yours...
Posted on Feb 25, 2008
We found elastic band around impella in pump its self!!!
Posted on Jul 25, 2010
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Why is my Fiat bleeping from the inside?
Its an audible warning, is your door closing properly? seatbelt connecting in the latch correctly? handbrake correctly released?, also check the boot and bonnet is secure and latched. Check the dashboard do you have any warning symbols, low oil fuel etc or a service indicator or warning light usually an engine shape or a service due message will be on your dash.If you are not sure go to a garage.
Jul 28, 2014 | 2006 Fiat Grande Punto
My Prima LPR660 will not start even though all the lights are on
It is likely the door latch microswitch is faulty and preventing the controller from confirming if the door is shut or not. Or it is possible the door latch mechanism is preventing door from shutting. It looks like this.
Prima Door Interlock
Jan 08, 2014 | Dishwashers
Hi, Should I press Start button first or close the door first and then push the start button? If I do the later, I can't see the control panel, although my dishwasher has been installed 1/2" lower than my...
If you are referring to the style dishwasher that has the controls on the TOP edge of the door, you are supposed to select the preferred cycle and options you wish to use, then press START while the door is OPEN. You will then have about 3 seconds to close the door. If you fail to shut the door in the allotted time, the program will cancel and you will have to repeat the steps. This information should be printed in the owner's manual under the operating instructions.
Jul 01, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Oct 04, 2009 | Candy Dishwashers
No lights on prima lpr 600 dishwasher just keeps filling up with water not draining
When there is no light at all, and machine is stuck with inlet valve open from start, then it is probably a faulty timer control board.
Before replacing the control board , the inlet valve, wiring harness, and additional electronic controls must be tested.
Try also unplugging the appliance from main, or tripping circuit breaker to cut power for ten minutes. ~This may unlock a jammed control board.
Mar 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Prima lpr 600
Sounds like something may be blocking the pump, causing overload -- may need a service call.
Feb 10, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Prima LPR 600
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No HEat Dry" button for 4 seconds (or more.  Try this.
Dec 27, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
Oct 29, 2007 | Tecnik TDW2677 Built-in Dishwasher
Prima LPR600
my prima LPR intregated dishwasher just not playing ball, has not been washing properly and had a continuous flashing and beeping fault, we cleaned out the filers and the arms which seemed to help the beeping problem but now have a fault where at the end of the cylcle its now showing another fault where it flashes 4 times but beeping has stopped what seems to be the problem and how do we fix ?
Oct 17, 2007 | Dishwashers
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
1,565 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
