Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Need to change secondary drive belt - Craftsman 20 hp 42 in. Deck Yard Tractor
  • 41 Answers
You need to remove top belt,then jack the rear of mower up.Loosen rearend bolts so rearend drops so you have enough clearce to R/R (remove and replace) secondary belt.
Posted on May 13, 2009
3.1 1993 chevy lumina cam sensor position? And how to take out
  • SERVICE AND REPAIR
Camshaft Sensor Follow this URL for picture:_
http://alldatapro.com/alldata/PRO~V416324719~C30660~R0~OB0~P3R0H~N/0/41746052/42417623/42417638/42422763/34853741/34857029/34857030/101366976/14461280/42437587/41882479
REMOVE OR DISCONNECT
  • Negative battery.
  • Serpentine drive belt and secondary air injection drive belt.
  • Power steering pump.
  • Electrical connector.
  • Bolt (1). Refer to Figure.
  • Camshaft sensor.
INSTALL OR CONNECT
  • Camshaft sensor.
  • Bolt (1) torque to 10 Nm (8 ft lb).
  • Serpentine drive belt and secondary air injection drive be!t.
  • Negative battery cable.
May 04, 2015 | 1993 Chevrolet Lumina
How to take cam sensor out
  • Negative battery.
  • Camshaft sensor.
INSTALL OR CONNECT
  • Camshaft sensor.
May 04, 2015 | Cars & Trucks
Trying to change the drive belt on a GTX 2446 Troy Bilt garden lawn mower rider can't get the pulley upper plate of the motor
You must remove the electric PTO clutch in order to remove the motion drive belt. Also it probably require you remove the bolts holding transmission if your going and secondary drive so can it off and on.
Aug 09, 2014 | Garden
Secondary belt
I assume you are referring to the drive belt? If so those are usually good for around 100,000 miles, I'm still running the original belt on my 97. To replace this belt is a big job and would take to long to type out here. If you don't want to buy a manual check and see if your local library has one.
Jun 21, 2013 | Harley Davidson Motorcycles
Hi I have a 307 xsi 2L 2002 I recently had timing belt/waterpump both changed and yesterday the fan belt but the car is now worse than before whining noise squeking when in idleing and driving accept in...
readjust the fan belt and check the condition of the pulleys The secondary air injector is showing a malfunction ---causes are ---wiring---AIR valve--- AIR sensor--- ECMI would be checking the wiring and connections as they may not have been replaced properly after the timing belt work. Replace with genuine units only as some after mark units are not compatible with the cpu.
May 27, 2013 | Cars & Trucks
Polaris 330 mag, barely moves in reverse? possible ****** problems??
If the belt has been changed, the button ramps in the secondary clutch should have been checked. The secondary clutch has 3 ramps that tend to wear, and this will wear the clutch out if not replaced right away. To remove the secondary clutch (rear clutch) remove the clutch cover and belt. Remove the bolt from secondary clutch and pull clutch off. The clutch is on a splined shaft so a puller will not be necessary. To check the ramps inside the clutch, rotate the outer sheave clockwise while holding inner sheave stationary. You should be able to see the ramps, if not they have worn completely gone and the clutch will have to be disassembled. Check this and let me know what you find. I will be happy to assist if you need to disassemble the clutch, Daniel.
Jan 12, 2012 | Polaris ATV
Need mowing belt for 54" deck
It appears there are two belts for your mower. The primary belt is JD part M143019 and secondary is M118685. Your traction drive belt is p/n M127523.
The secondary belt for a 54 inch C deck is M154960 the other belts are the same as above.
I have used these folks for replacement belts before.
http://www.mfgsupply.com/MowerBeltsJD.html
I hope this helps.
Jun 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a problem with my 1982 yamaha xl3
There are two clutches on a snowmobile. The primary and secondary. The primary is the one on the engine, the secondary is the bigger one closer to the rider.
Your belt should sit "just above" the top edge of the secondary clutch, and at the bottom/center of the primary clutch when the snowmobile is not running. You can normally tell if the belt is worn by looking at where it sits on the secondary. If the top of the belt is below the top edge of the secondary clutch, it's worn and should be replaced. Belts are typical wear parts and are just replaced (not adjusted) when worn. I go through a few belts a winter and ALWAYS carry a spare.
Jan 24, 2010 | 1982 Yamaha XS 400
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Hello kerry_byrum:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. Select Ground Drive for a Breakdown of the Belt and Other Drive Related Components.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
185 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
