Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Hitacho 60V500A that just stopped working
I have a Hitacho 60V500A that just stopped working,. It has no picture and seems to have no sound. Indicator power light does come on. My first stepp will be to replace the bulb. Though I don't believe this will result in a complete fix since I don't believe the sound would stop working as a result of a blown bulb. Does anyone doscumentation that can take me through the procedure for identifying the root problem,
  • Anonymous May 13, 2009
    i have the same problem just happened yesterday please help
5 Suggested Answers
  • 3 Answers
SOURCE: rastor needs adjustment on 60v500a
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Jan 19, 2009
SOURCE: Hitachi 60v500a projection turns itself off
i have the same problem, did you ever get an answer?
Posted on Jul 01, 2009
jhinsincity
  • 616 Answers
SOURCE: My TV is Hitachi 60V500A rear projection TV. I
Remove the lamp cartridge and make sure the wiring is secure, if ok then reinstall, slowly and carefully making sure the lamp is seated correctly, do all this while the tv is unplugged - of course, also make sure the all the covers on the tv are securely installed or the tv will not power up. good luck
Posted on Nov 07, 2010
eagle338
  • 4889 Answers
SOURCE: 60VS810 60 in. Rear Projection
If you look inside the lamp compartment, it has a switch. Even though the door is closed, it is very easy to miss the switch. Ensure that the door is hitting the switch when you close it. There are 2 slender scale kind of strips that are responsible for triggering the switch. If they are hitting the switch, then manual turn the lamp switch on and off to see if the switch changes the LED pattern at the front.Let me know what are your observations so that I can suggest what to try next.
Posted on Sep 10, 2011
No sound and no picture
The green indicator merely lets you know that power is getting to your TV. The absence of picture and sound could be due to power supply failure
May 18, 2013 | LG Televison & Video
I have no picture. the power light and the lamp light stay on all the time. you can't turn it out unless you unplug it. could this be the lamp? it's a hitachi 60v500a 60inch projection hdtv
was the set worked on lately? And also have you ever changed the lamp? The first thing I would replace is a C958 (100uf/35v) Capacitor.
Apr 11, 2008 | Televison & Video
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
Lamp light on after i replaced the blown lamp Hitachi 60v500a
Was the tv working before you replaced the lamp? if it was then make shure you have reinstalled the new lamp and the door exactly as removed, there is a disconect switch on the door that has to close when the door is reinstalled,or sometimes the ballast may go bad at the same time.Hope tha t will help you fix it.
Mar 19, 2010 | Televison & Video
Power light is on but no picture or sound
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Olevia LT42HVi 42 in. LCD Television
Hitachi 60V500A Cracked Screen Replacement
You have probably reversed the inner screen (Fresnel Lens) when you reassymbled the screen. It will give you the same effect.
Hope this helps,
Skyassy
Jul 04, 2009 | Televison & Video
May 31, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi 60V500A
Good Day, artisticpool;
Suspect loose cable see picture:
If okay suspect light engine.
Good Luck, big IRISH.
Aug 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Convergence hitacho 61swx10b
To enter digital convergence adjustment
mode without removing the front speaker
grill, please do the following:
1) Press “Magic Focus” button on the front
panel.
2) While “Magic Focus” is running, press
Magic Focus button again to “Stop”.
3) Press “RECALL” or “STATUS” button after
“STOP” OSD appears on the screen to
enter digital convergence mode.
4) Proceed with convergence adjustment
and save the data.
5) Do MAGICS FOCUS sensor initialization.
6) To exit, press POWER button on the front
panel.
7) Normal and through 1080i modes are
stored separately. Each one has it’s own
memory setting.
Aug 11, 2008 | Philips 60P8342 60" Rear Projection...
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
161 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
