I have a 65 inch hdtv projection tv model# ws65615 . I'm having a problem when I hit the DEVICE or AUDIO/VIDEO buttons on the remote OR the tv control buttons. The tv does'nt respond to those commands. Instead the tv shuts off after about thirty seconds later and then the green power button starts blinking. I have to reset it to turn it on again. once i turn it on I can use any command buttons on the remote or tv buttons. all the buttons work fine, except when I hit the DEVICE OR AUDIO/VIDEO buttons. then the tv shuts off again. In other words I cannot watch any other devices on the tv because the DEVICE OR AUDIO/VIDEO buttons get no response. Can you help? Thanks, Wayne
Need actual Mfg. so I can have Comcast program the Remote??? Comcast has NO listing for the program numbers for Vivitek.
Posted on May 13, 2009
Video on 65 inch Mitsubishi Tv model WD-65638 is not working how may i reset this or even fix the situation.
If you have the original working Mitsubishi remote you can try a soft restart:
Menu, 1,2,3, enter
SD TECH
Aug 31, 2011 | Mitsubishi WD-65638 65" DLP HDTV
I have a Mitsubishi WS-65513 65 in. rear projection HDTV. I recently hooked up a DVD player to the Component 2 cable inputs but I cannot find the Component 2 selection on the 'Device menu' to tell the TV...
If one or more of the inputs is "missing" or not there you may need to do a hard reset of the TV with the original remote.
If you want to try this confirm the actual model number and I will tell you how to do it.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65513 65" Rear Projection...
65 inch tv turned on and volumn went all the way high remote does not work also can't change devices
Make sure the button either on the remote is not depressed all the time or on the front of the television!! This will be the main reason that the volume is going to MAX all the time. Usually if you press any button on the tv or remote and hold it down such as you mentioned, it will lockup the microprocessor to that function specificly and it won't take anyother instructions until you unstick the button or get it to stop going all the way UP!
Try that and let me know if i solved your problem.. God luck from the TV GURU
Jun 09, 2010 | Mitsubishi WS-65311 65" Rear Projection...
A small crack in my hitachi tv screen
very espensive. new. try to find used one.  change yourself.
Dec 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound
A DVI cable does not have an audio connection, along with the DVI you still have to run an audio line from the device (DVD player, cable box, satellite receiver) to the TV. HDMI contains both audio and video.
Sep 30, 2008 | Hitachi 57F500 57" Rear Projection...
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
My sony 65 inch projection does not work
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 26, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Device Menu not working
Could have a stuck button or a corrupt e-prom, but lets try kicking this set in the head, Now these reset codes are model dependent so this code will not work for every set out there but this reset is for the WD-62525. with the set on and with the original TV remote hit the keys in this sequence, MENU-2-4-7-0 this will bring up a service menu, the cruiser should already be on "Initialize" so simply hit enter. this will reset the TV to factory defaults and may fix your problem
Sep 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
REMOTE LOCKED
On most television remotes, there are buttons to control other units. If these buttons are hit by accident, then the remote acts like you described. Look at the top of the remote and find the button that says TV. Push it and it should start working normal. Since I'm not at my shop, I don't know the exact button or names. If this doesn't work, respond to this post and I will reply when I have a schematic in front of me.
Aug 05, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
